code P1762 help
Old Dec 2, 2012 | 01:30 PM
Shizzle99's Avatar
Shizzle99
Default code P1762 help
My '99 Ram keeps on throwing P1762 even after replacing the sensor solenoid combo.
Whats next to take a look at?
Old Dec 2, 2012 | 02:00 PM
zman17's Avatar
zman17
Retired Moderator - RIP
By combo, do you mean you replaced both, Gov sensor and Gov solenoid? Or you replaced the TCC/OD solenoid unit?
Old Dec 2, 2012 | 05:22 PM
Shizzle99's Avatar
Shizzle99
Gov sensor & Solenoid, and to add, the speed sensor on the OD.
I was told by several places the OD solenoids very rarely go bad.
The truck will start off in 2nd, I get it going, cycle the key on and off and it will start off in 1st till next time.
My speedometer tends to only work in the warmer months as well, the speed sensor in the differential is new as well.
I drive a Charger when there isnt snow (April till whenever) and then drive the truck. 80% of the other times it sits unless I need to haul something.
Old Dec 2, 2012 | 05:49 PM
dlyter09's Avatar
dlyter09
Might be time for a rebuild
Old Dec 2, 2012 | 07:22 PM
Shizzle99's Avatar
Shizzle99
I rebuilt it around 2k miles ago, other than the Gov solenoid issue it shifts fine.
Old Dec 2, 2012 | 07:30 PM
dhvaughan's Avatar
dhvaughan
google turned up this unexpected possibility.
Ok. On a gas engine there are 2 main factors that can set this code. The first one, seemingly transmission unrelated, is a partially shorted upstream or downstream oxygen sensor. The sensors share the same 5 volt reference as the governor in the trans, and a bad sensor can sometimes set this code without setting an o2 sensor code. To check for this you can unplug the sensors, clear the codes and drive the truck to see if the problem still is there. The most likely cause for the problem is a bad governor pressure solenoid or transducer. These both mount to the valve body and are replaced together when there is a governor problem. If the o2 sensor test does not change anything, drop the pan and replace the solenoid and transducer (pressure sensor)
Old Dec 2, 2012 | 07:55 PM
Shizzle99's Avatar
Shizzle99
Hmm I am going to have to replace the O2 sensors then, not all the time, but the couple of times I had pulled the codes, the code for the downstream O2 was one of them.
Thanks
Shawn
Old Dec 2, 2012 | 09:17 PM
justin case u12's Avatar
justin case u12
it is the down stream o2 i just got mine done after weeks of searching for shorts now it shifts great *pass side down stream o2* un plug it an test
Old Dec 2, 2012 | 10:17 PM
Shizzle99's Avatar
Shizzle99
I wonder if that cat came apart and a chunk hit the sensor. It rattles, but it is hard to tell where it is coming from, plus the sensor is original to the truck and has 60k miles.
Old Dec 2, 2012 | 11:30 PM
dhvaughan's Avatar
dhvaughan
unlikely. when they short out its more likely the heater circuit burning out and shorting the 12v heater to the 5v signal wire.
