Will 15" Wheels Fit Our Trucks?
Old Dec 2, 2012 | 09:48 PM
ChillyPhil's Avatar
ChillyPhil
Default Will 15" Wheels Fit Our Trucks?
I heard yes and no about this issue. But I found a good deal for 33s on 15" wheels but I got told the rotor will run the inside of the wheel. Is that true? I'll be getting a 2.5" leveling kit Wednesday of that helps.
Old Dec 2, 2012 | 09:52 PM
Johnn123's Avatar
Johnn123
Might have to grind the calipers. I donno Ive seen 15's on these trucks before.
Old Dec 2, 2012 | 10:53 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Short answer: No.
Long answer: Not without careful fitting, meaning, grinding the calipers.
Old Dec 3, 2012 | 09:02 AM
ChillyPhil's Avatar
ChillyPhil
Da*n them were nice too, but i don't think I'm going to be grinding my caliper. Thanks guys.
Old Dec 3, 2012 | 10:33 AM
oxymoron29's Avatar
oxymoron29
Short answer: No.
Wrong. 15" steelies will fit fine. 15" Aluminum wheels are a touchy subject. I'm running 15x8 Pro Comp D slots with no caliper mods on my 97.
I believe 00-01 had upgraded larger calipers so grinding is required for them.
OP, you will be fine
Old Dec 3, 2012 | 10:45 AM
dipsherry's Avatar
dipsherry
i have 15's on my truck
They fit the half ton axles no problem no rub not a single issue
They fit my dana 60 and 70 with only grinding on the calipers
Simple answer 15's fit
Old Dec 3, 2012 | 11:14 AM
kejobe's Avatar
kejobe
IIRC, only the dual piston calipers ('00-'01) need to be ground for 15s to fit.
Old Dec 3, 2012 | 11:28 AM
redneck_ram's Avatar
redneck_ram
i was able to fit 15's on my '01 without any caliper grinding. they were steel wheels with 35's on em.
Old Dec 3, 2012 | 04:02 PM
97dodge5.2ram's Avatar
97dodge5.2ram
i have 15 inch steels on my truck with 31's and they work just fine
Old Dec 4, 2012 | 06:49 AM
ChillyPhil's Avatar
ChillyPhil
Are you guys 100% sure their fit? I want the wheels/tires but I would hate for them not to fit cause I don't wanna grind anything. Here's a picture of them:
I plan on painting part of th inside black so it'll look better with my truck of if i get them.
