1996 ram 1500 code 3 help
Old Dec 3, 2012 | 04:34 PM
pimpinphil's Avatar
pimpinphil
Default 1996 ram 1500 code 3 help
i have just swapped out the trans for a reman unit. went to start it last night,an it started right up without issues. ran for approx 2 mins. and started stumbling,and shut off on its own. tried restarting it,cranked for approx 5 sec. and it restarted,ran ruff,for a couple secods and shut back off again. now it wont start at all. checked for spark and i dont have any. checked coil wire to the distributor,and dont have any spark their either. checked the codes,and it throws code 32 which relates to egr vavle/circuit issues. im thinkin though that the egr issues wouldnt keep the truck from running would it??? maybe just a bad coil ??? thanks.
p.s. checked the wiring around the trans swap. nothing out of the ordinary... thanks again
Old Dec 3, 2012 | 04:52 PM
pimpinphil's Avatar
pimpinphil
i checked the wiring to the coil also,i dont have any power in those wires either.... im kinda lost now....
Old Dec 5, 2012 | 12:50 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you remove the crank sensor before uninstalling the tranny and reinstall it after the tranny was back in? If not, it is most likely damaged.
