Rebuilding my 5.9 Magnum, suggested upgrades?
Old Dec 26, 2012 | 06:55 PM
  #61
Ziggy2112's Avatar
Ziggy2112
Originally Posted by dlyter09
1.7 roller rockers.. Get some new clearwater heads.. new timing chain... and do the plenum fix when motor is out.. After all that get a SCT tuner and you will have yourself a good reliable motor and you will be pleased with the performance...
All of that stuff can be done for right around 1k
why new heads with the rocker change? is the stock heads that bad? can they not handle the new rockers?
Old Dec 26, 2012 | 07:00 PM
  #62
dlyter09's Avatar
dlyter09
The stock Magnum heads are notorious for cracking... Upgrading isnt to expensive and is worth it in my eyes.. You can use factory heads with the rockers without any issues..
Old Dec 26, 2012 | 07:28 PM
  #63
aofarrell2's Avatar
aofarrell2
Not expensive? $800.
Old Dec 26, 2012 | 07:37 PM
  #64
dlyter09's Avatar
dlyter09
I never said not expensive.. I said it wasnt TO expensive lol
Old Dec 26, 2012 | 07:43 PM
  #65
aofarrell2's Avatar
aofarrell2
lol....
Old Dec 26, 2012 | 07:47 PM
  #66
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
$1600 isn't that bad for new heads that are better than factory. If you don't have the money, well, you shouldn't have bought a Dodge Ram.
Old Dec 26, 2012 | 08:49 PM
  #67
aofarrell2's Avatar
aofarrell2
No $800 for both.
Old Dec 26, 2012 | 09:18 PM
  #68
34blazer's Avatar
34blazer
i like the comment about not using aluminum pistons with high power ignition LOL. have to say that ive never, ever, saw an engine with anything other than aluminum alloy pistons.
besides that, factory magnum heads are known for cracking, more commonly in the front/back cylinder exhaust bowls. when i rebuilt my engine, i ported the heads and found exactly where the cracks were in the bowls. didnt have new heads in the budget so they went on the new shortblock(dumb idea) but have held up for 40K miles and towing my other truck cross country. valve springs are weak on these engines, 1.7 rockers will cause float issues around 5K rpms. its a good idea to find some better springs/retainers/locks for cam and rocker upgrade. it may also be a good idea to take the back two pistons out and check the size. due to the poor coolant circulation on the back two cylinders, they tend to run a little hot. if the engine ever overheated, the piston skirts may have collapsed enough to cause piston slap. ive found it on a 360 mag with milage as low as 30K miles, and it was babied. if you need new pistons, keep in mind that summit lists LA pistons all the way up to 96 iirc. i bought that set and found they were wrong. LA heads had the open combustion chamber with little to no quench areas, among a couple of other differences. overall the magnum heads flow really well in stock form, if you can find a set with no cracks. iirc, intake flows ~240-250 cfm, exhaust needs a little help. eitherway, they are decent heads. to address the comment about too strong of an igniton system, ive never heard of that before. with higher compression, a stronger spark or smaller plug gaps help keep the spark from being blown out, same applies for boost/nitrous. also, you may be able to find a nice set of magnum R/T heads, last i heard they werent being produced anymore. iirc edelbrock had some decent OTS heads for the magnum. i may still have a flow sheet comparison somewhere if anyone cares.
Old Dec 27, 2012 | 12:02 AM
  #69
keilkravec's Avatar
keilkravec
Far as heads goes, check Hughes Performance website. The sell magnum heads in cast iron and alot of other modified parts that are just stock stuff ported out.
Old Dec 27, 2012 | 08:50 AM
  #70
And they command a premium price for those too......
