Cant shift out of 2h, knowledge requested
5" suspension 3" Body and thanks for gettin back...as merc stated i think i may just be looking at worn parts as its difficulty in shifting is when rollin down the road not while stopped and off...overhaulin time means excuses for upgrades
Time for a np203/205 set-up
http://www.northwestfab.com/NP203NP205_c_77.html
I liked the idea of the Ramzilla tranny too..
ahhhhahaha!!
Research research research baily. Know what you want to do with the rig.
Another interim replacement is replacing the 231. I'm not bombing on the doubler. My post is an inside comment b/t Merc and I from earlier this year. I'm still contemplating it.
You can also source the same 231 from Jeeps.
Additionally you can buy a Teralow 4:1 which replaces internals.
Now with this 6,000 lb monster
it seems to be a weak link so something will probably need to done. As you said before though research, research, research....and then weigh that against what I can afford.
Just for the sake of udating this for others who may feel like they were in a similar situation here some other things ive discovered about my little problem...
...with the truck off and in neutral shifting into 4lo is easy however shifting into 4h while doable still feels harder than it should be and does not give one the same confident feeling that it has shifted....
The 4wd light does not come on....checking into this more now but believed the heavily corroded 4wd actuator was the culprit....did do the make shift test of pulling one vac line off while in 4wd to engage the front..put line back on...then pull opposite line to disengage and put back on...
I got no results with this but did order in a new actuator and actuator housing if for nothing else than because i couldnt stand the sight of this one....I'm going to check for vac in the lines and work this out further but as i said just updating.
