Yay, my catalytic converter clogged!
Old Dec 9, 2012 | 06:20 PM
Annihilator_X9's Avatar
Annihilator_X9
Default Yay, my catalytic converter clogged!
Fired her up yesterday and I noticed my exhaust was really quiet. Well, I couldn't rev past 2.5k and could barely hit 50mph. Quick fix was to drill some holes in the cat to get me to work because my Mustang doesn't see snow or salt. It's loud...
So I'm gonna go with the JEGS Off Road Y Pipe. You guys like them? Since I'm in MI I don't need to pass emissions.
Also, how much louder does it make your truck?
Old Dec 9, 2012 | 09:39 PM
If you have a decent muffler, you won't really notice too much of a difference. It will be a bit louder, but, not a whole lot. You WILL notice the power difference though.
Old Dec 9, 2012 | 10:20 PM
Is your plenum fixed?
Old Dec 9, 2012 | 10:22 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Dude, it's on his sig.
Old Dec 9, 2012 | 10:28 PM
stewie01's Avatar
stewie01
Sigs are like stickies, no one reads them.....
Old Dec 9, 2012 | 11:10 PM
So is that a yes?
Old Dec 9, 2012 | 11:38 PM
dodge dude94
It said he did the Hughes kit.
I would guess he didn't change the cat after he did it, so it finally just gave out.
OP?
Old Dec 10, 2012 | 07:21 AM
dhvaughan's Avatar
dhvaughan
i started by surgically gutting my cat, then reconnecting the pipe behind it. it sounded like ****, clattery, like i'd installed a motorcycle expansion chamber...
next i got the jeggs y-pipe. it fit perfect. i used a couple of walker sleeve type clamps to avoid permanently crimping or welding the pipes. i wanted to leave my options open to remove or change things. one 2 inch, one 2.5
where the y-pipe attaches to the exhaust manifold studs, i used plenty of anti-seize on the studs and was a little too tentative and didn't torque them tight enough the first time. it had a nasty sounding leak, so i went back and retorqued them correctly to quieten that.
i've got the stock muffler and exhaust pipe turnout - and its a lot louder than i expected at the exhaust pipe. not too loud at the drivers seat, but when in a garage or passing a wall on the right, its a lot louder than i expected.
Old Dec 10, 2012 | 08:13 AM
Annihilator_X9
Haha, so true... so true.
And yes, I fixed my plenum without replacing the cat. It was still flowing okay so I didn't bother at the time. I have an aftermarket muffler on it that's pretty aggressive so I might need to tone it down after this... or not.
Old Dec 10, 2012 | 09:47 AM
stewie01's Avatar
stewie01
I cut my cat out, welded in pipe, and I'm still running the stock muffler, and it's noticeably louder, you can hear it a bit with the passenger window down if the exhaust noise has something to bounce off. I had a video of it, but I think I deleted it
What kind of muffler are you running?
