Loose noise under my 1998 Ram extended cab
Old Dec 10, 2012 | 02:14 PM
merc225hp's Avatar
merc225hp
^^^ 2 piece DS is only found in 2500 and 3500 models not on a 1500 so don't go looking for a hanger/steady bearing. Got a spare tire under there still? take it out see if that helps, grab the exhaust shake the sh** out it, get in the box and jump up and down see if you can make the sound, box bolts checked, bumper bolts, hitch, wheel nutz, hub caps have rocks in them, if you have hub caps of some flavor.
Old Dec 10, 2012 | 02:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by elvis-77
Ok, thanks, what do you check on it and how do you go about checking it?
You first need to check and see if you even have a 2 piece drive shaft, somehow I highly doubt it.
Old Dec 10, 2012 | 02:16 PM
elvis-77's Avatar
elvis-77
Ok, I'll check those this evening. I already tried the spare tire and exhaust, but I'll give the others a try.
Old Dec 10, 2012 | 04:28 PM
cruzer55's Avatar
cruzer55
My 94 1500 came stock with "twins"&carrierbearing" 135 wb,longbed....
Old Dec 10, 2012 | 04:39 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Sound cool.
Specs? Pictures?
Old Dec 10, 2012 | 04:53 PM
merc225hp's Avatar
merc225hp
Originally Posted by cruzer55
Check carrierbearing(2peace driveshaft)when there ready to go they make all kinds of noise.Just a thought............
He has a 4wd never had one in it, 2wd yes they had 2 piece shaft.
Old Dec 10, 2012 | 05:43 PM
baileysoffroad's Avatar
baileysoffroad
bushings in the leaf springs?
Old Dec 10, 2012 | 06:16 PM
elvis-77's Avatar
elvis-77
I didn't know the leaf springs had bushings in them. I'll check that also.
I also noticed this evening it seems more like its right behind the cab or the rear of the cab. It's just still strange that it only does it when the rear wheels hit the bump or even uneven pavement.
Old Dec 10, 2012 | 06:23 PM
merc225hp's Avatar
merc225hp
Possible gas tank strap rusted out? Cab mount? tranny mount
Old Dec 10, 2012 | 10:03 PM
Sheriff420's Avatar
Sheriff420
Originally Posted by zman17
Check front lower shock mount bolts, exhaust and exhaust heat shields, gas tank straps, bed and body mounts and steering column bushing where it exits the firewall under the brake booster, tranny and or transfer case mounts. Also remove the tail gate and see if it still makes the noise.
My first thought. There are plastic caps that go on the hinge point where the tailgate attaches to the truck and if they wear out or don't get put back in when the tailgate is off then it will make some noise.
