O.D. On off button use.
Old Sep 8, 2005 | 02:43 AM
BransonV10's Avatar
BransonV10
Default O.D. On off button use.
Hello- I feel like an idiot asking this question but here goes. When should you use this button? I know I have turned of the O.D. and left it off towing. I however want to increase gas mileage towing but I hesitate because I am not sure about the operation of the O.D. on/off and when you should use it. Thanks..
Old Sep 8, 2005 | 11:20 AM
Ram4Aaron's Avatar
Ram4Aaron
Default RE: O.D. On off button use.
I leave mine off until I get to highway speed. Once I'm crusing along it seems fine and doesn't shift out unless I'm on a big hill. I have the 5.9L and I'm sure the V10 would be easier. Of course I only tow a snowmobile trailer with two sleds on it.
Old Sep 8, 2005 | 12:46 PM
steve05ram360's Avatar
steve05ram360
if your towing a light load you can leave the OD on, otherwise, I'd leave it off. the OD units on these trannys are not that great and are prone to failure. towing a heavy load in OD is asking for trouble...
Old Sep 8, 2005 | 07:46 PM
shott8283's Avatar
shott8283
if im just bombing around town... short streets and alot of stop and go ill leave it off... my tranny shifts hard sometimes and my drive train has ALOT of slack in it for some reason so i just run my 3 gears around town but if im on the interstate or freeway... ill turn it on for feul milage ofcoarse..
Old Sep 10, 2005 | 03:59 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I keep mine off until I hit the Interstate, which I drive to work for 35 miles. Around town and all that I keep it off as well.
Old Sep 10, 2005 | 06:04 PM
Trippen's Avatar
Trippen
Od works great for all the time use if you have the right gearing.... ...4.10's or higher with 31" and up tires will keep the truck in a good RPM range and give you good highway RPMS too Mine ran fine untill I opened the exhaust. Now I am an OD off switcher if I remember to do it when I start it up. Of course I allways use the OD OFF when towing.
