Dodge Ram 5.9 Magnum 3" exhaust options?
I guess I wasn't being obvious. I'm trying to tell you that a factory, off the shelf 00-01 Y-pipe has the characteristics you desire according to the link I put above. I'm assuming they are interchangeable in the sense that the routing/mounting is the same but the pipe sizes and inlets to the cat are different....
^^Seems to be that way. I just checked out Walker's catalogue and indeed it seems to be 2.5" outlet for 00-01. Someone should fix that post...
The only other option is getting a 00-01 Y pipe from a JY (or buying new), and using an adapter such as: http://www.summitracing.com/parts/wlk-41973/overview/ using 2 clamps side by each. See it used here in a vidya: https://www.youtube.com/watch?v=gw2757T20j0
^beat me to it
^beat me to it
Yes, I'm aware of being able to do that, however, would still have some restriction of the 2.5" converter outlet - was trying to avoid that by using an actual 3" inlet/3"outlet converter..
