2nd steering box still leaks fluid!
Old Dec 13, 2012 | 08:40 AM
MoJoeee42's Avatar
MoJoeee42
Default 2nd steering box still leaks fluid!
So I have a 2001 Ram 1500 That was leaking ps fluid out of the bottom seal of the steering box. Rather than buying a seal kit I opted to replace the whole box. Installation went fine and I even installed new ps hoses. About 25 miles later I noticed even more ps fluid dripping from my steering box. I figured the parts store sold me a faulty box so I went back and got a new one (free of charge). Another 30 miles down the road I run in to the same exact problem. At this point I am at my wits end. I highly doubt that I purchases 2 faulty steering boxes. Any advice or tips would be greatly appreciated!!
Old Dec 13, 2012 | 08:43 AM
Scooter78's Avatar
Scooter78
Is it leaking from where the steering shaft attatches? Can you post a pic of where it is leaking?
Old Dec 13, 2012 | 08:46 AM
Talk to who you got the steering box from. See if you can get your money back, then, get a redhead, or borgeson box.
Old Dec 13, 2012 | 08:53 AM
MoJoeee42's Avatar
MoJoeee42
No it is leaking from where the pitman arm attaches to the steering box.
Old Dec 13, 2012 | 01:03 PM
clipper77's Avatar
clipper77
Pitman shaft seal.
As stated before, get a refund, or fix the seal.
Looks like there is also fluid leaking down from where the hard lines connect to the box.
Old Dec 13, 2012 | 01:06 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by clipper77
Pitman shaft seal.
Agreed.
Any chance you check the lines to the PS pump. Oring on the high pressure side likes to retire on occasion.
Old Dec 13, 2012 | 03:54 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Cross threading is also a possibility. The lines should screw in all way by hand first. And yes, make sure new orings are used.
Old Dec 13, 2012 | 05:10 PM
MoJoeee42's Avatar
MoJoeee42
The lines are all brand new and I hope I didn't cross thread anything but I will know more when I take it all apart in a few hours. Would a cross thread or faulty o-ring really cause the pitman seal to blow out like that? I'm thinking more along the lines of replacing the power steering pump, but really I'm just taking shots in the dark.
Old Dec 13, 2012 | 06:14 PM
clipper77's Avatar
clipper77
Don't just throw money at it.
Do your best to diagnose the problem and fix it as efficiently as possible.
I can't see the pump as causing the seal to go like that.
Could have been defective from the factory.
Let us know what the dealio is when you look at it.
Old Dec 13, 2012 | 07:35 PM
coram1's Avatar
coram1
Could pump be causing high pressure to build, as in clogged by-pass?
