97 Dodge Ram 1500 SLT 5.9L CLY 4/7 missfiring with a P0300 code as well
Old Dec 14, 2012 | 09:43 AM
CryptFiend's Avatar
CryptFiend
Default 97 Dodge Ram 1500 SLT 5.9L CLY 4/7 missfiring with a P0300 code as well
Okay guys please help me out here cause I am running out of options. I have 3 codes showing on my 97 1500 for cylinder 4 and 7 misfiring and then P0300 which is multiple random misfires.
Here is what I have already done: I changed sparkplugs and tested the spark. There is spark. I swapped out the fuel injector in the #4 cylinder and checked the ohms and its good. The distributor cap is relatively new so it should be fine, plus i check to see if the plugs are getting spark and they are. I changed the O2 sensor's. Please note that I have headers back to a cat with straight pipe off the cat.
The truck has about 240k on the eng but was running fine until the other day when i was leaving work to get on the freeway and a jumped on it and took it to about 4800RPMS. When i got off the freeway the whole truck was shaking at idle with it about 200/300 rpms low. When i am going about 40-50 MPH with overdrive on the RPMS will be around 1400, if i gas it just a little to speed up they jump to 1500+/- 100rpms and then drap to 1300ish and the whole truck shakes. I figure this has to do with all the misfires. Please I am running out of options other then the timing chain jump a tooth or the PCM when out...someone HELP ME!!!
Old Dec 14, 2012 | 03:22 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Shaking at 40-50 MPH is the misfire.
There is a TSB for the sparkplug wire routing technique. I think it might be in the 2nd gen faq section. It specifically dictates where to put the plug wires, mainly numbers 4,8, and 7. Go find it, re-route your wires and see what happens.
Old Dec 15, 2012 | 10:17 AM
CryptFiend's Avatar
CryptFiend
Thank you for the input. I have been searching and can't find that anywhere on the thread. WHich sucks Because I would really like to try it. If you have any idea of a more specific spot could you let me know. That would be awesome
Old Dec 15, 2012 | 09:23 PM
jasonw's Avatar
jasonw
Site Moderator
If you'd post in the correct section, you'd be able to find it quite easily. :-)
https://dodgeforum.com/forum/dodge-r...s-section.html
I'll give you one hint for the TSB regarding the spark plug wires' routing: its in the 2nd Gen Ram DIY section, and you can find how to get to that by reading whats at the above link.
Old Dec 16, 2012 | 04:09 AM
blindsided's Avatar
blindsided
The post in the DIY section is a real good reference but the photo's don't work. I wound up using the link below along w/ the one in the DIY and all worked out well.
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Old Dec 16, 2012 | 08:41 AM
97ramrod1500's Avatar
97ramrod1500
if the rerouting of the spark plug wires doesn't work do a cylinder compression test. with 240k + miles its possible you have low compression
Old Dec 16, 2012 | 12:55 PM
CryptFiend's Avatar
CryptFiend
I did a compression checkl they are all at like 60 lol so yes they are all low. I look at the sparkplug rerouting. I think its already been done. cause all of the wire holders and what nots are on the truck already.
Old Dec 16, 2012 | 01:28 PM
dlyter09's Avatar
dlyter09
With that low of numbers I would start looking for a new motor..
Old Dec 16, 2012 | 01:44 PM
Seconded. OP is 40% below minimum spec. No wonder it doesn't wanna run right.
Old Dec 16, 2012 | 02:13 PM
blindsided's Avatar
blindsided
Suddenly I feel a whole lot better about my numbers. I wouldn't even think the engine would run with compression that low.
