quick add-a-leaf question
Old Dec 20, 2012 | 08:22 PM
  #21
Halojm's Avatar
Halojm
+1 The only post that matters.
There should be at least 3/4" of ubolt threads past the nut when tqd. Glad your not on the road near me. Buy the right parts for the job.
First, there was barely if even 3/4 of an inch on mine from factory. Second that 3/4 of an inch is doing absolutely nothing, so way is it needed. All the holding threads are in the nut, anything exposed is not doing anything. As long as your using the entire nut.... It's good.
Old Dec 20, 2012 | 08:24 PM
  #22
97ramrod1500's Avatar
97ramrod1500
Originally Posted by stewie01
Welp, he got his answer, time for jkeaton to close this thread! (that was not meant for humor)
thank you, is there no way to close these threads on our own?
also, because I have so much money for everyone to spend what is the size of the new U bolts i should pick up?
-square or round?
-length of legs?
-length inbetween legs?
this should be the last question and the thread can be closed. thank you for all the helpful answers
Old Dec 20, 2012 | 08:28 PM
  #23
merc225hp's Avatar
merc225hp
-square or round?
-length of legs?
-Size 9/16
-square or round? Square
-length of legs? Add 1.5" to your currant u bolts
-length inbetween legs? Width between is 2.5 inchs
Old Dec 20, 2012 | 08:32 PM
  #24
Halojm's Avatar
Halojm
-square or round?
-length of legs?
Just make sure you have 12" sticking out after the nut is tight, just in case. If your gonna or need to buy some, they should be square bolts 2 1/2 in between the legs, measure the length of the one on your truck now, and add 2" unless you want a Badass truck like I see running around with 10" stick down.
Old Dec 20, 2012 | 08:35 PM
  #25
merc225hp's Avatar
merc225hp
Link on how to measure a ubolt
http://www.customsuspension.com/stor...products_id=62
Old Dec 20, 2012 | 08:39 PM
  #26
97ramrod1500
I don't know the length of the current u bolts?
I'd measure them now but i'm parked in 1+ ft of snow lol
Old Dec 20, 2012 | 08:43 PM
  #27
merc225hp's Avatar
merc225hp
Not including the aal how many leafs in your pack, include the thick one as well. If you don't know this then we can't help you.
Old Dec 20, 2012 | 08:47 PM
  #28
97ramrod1500
Umm yeah i don't know this at the moment. I was under my truck last weekend but didn't take a good look at them. All I know is its all original with a 3.5" or so block. (which is also original)
Old Dec 20, 2012 | 09:03 PM
  #29
merc225hp's Avatar
merc225hp
4 pack leaf spring ubolt is 10.25 as you don't know what pack is in there that's the best I can do.
Old Dec 20, 2012 | 09:08 PM
  #30
97ramrod1500
ok thanks. I'll try to look tomorrow night if i have a chance to pull it in the shop at work. I know my truck came with the tow package from the factory so i'm not sure whether or not it has aditional leaf srings.
