quick add-a-leaf question
Haha no they don't, for a cheap kit you will need to buy them and you should never reuse them anyway.
Edit: As answered no there is not enough thread on the stock u bolts. Did you get new center pins/bolts for the leaf pack with the kit?
Have a read
http://www.eatonsprings.com/ubolttorques.htm
Have a read
Be ready for a stiffer ride when you get those installed. I feel every bump in my truck since I added a lifting leaf.
Also, it's a good thing you started with the PB blaster already, that stuff is a really weak penetrating fluid and since you live in a salt state it will probably take a while to actually penetrate the rust.
Have a read
Have a read
I've added a leaf to almost every vehicle I've ever owned. Always changed the U bolts. The locking nuts are crushed to oval shape on the ends so it's critical that some amount of thread protrudes or they can back off.
If you are an almighty auto tech why are you asking a stupid question like this in the first place?
^Good question and funny picture lol
Wrong...
If a 2" AAL came with ubolts as a package they would have to make different size ubolts depending on the size of the original leaf pack on each persons truck (Hence why they just leave the buying of the ubolts the owners responsibility). What if I wanna put a 2" AAL on top of my 10" lift leaf springs? And some other guy just wants to put a 2" AAL on his stock leaf pack? Those ubolts aren't gonna be a one size fits all.
I'm not great at explaining things but you get the idea.
Just buy longer ubolts.
First off i never called my self a master tech, greatly experienced tech and i sure as hell didn't call myself an almighty tech. I only have a few years of experience in the field therfore i am still learning. As i stated earlier; i have worked on these suspension systems before but have never installed an AAL. I have never needed to replace U-bolts before unless they were unusable. Therefore I had asked the question in the first place because I did not know how much threads I would need to put in an extra leaf. Because I have never insalled one before, I did not know how thick the actual leaf was.
Next time you decide to be a smart ***, read through the entire thread and understand what you are reading. I clearly stated why I had asked the original question I have already gotten my answer.
