Buying a Magnum 360
Old Dec 18, 2012 | 12:51 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
My bad.
Old Dec 20, 2012 | 09:23 PM
98Ramboy's Avatar
98Ramboy
What about getting a stroker kit to make it a 426?
Old Dec 20, 2012 | 09:41 PM
merc225hp's Avatar
merc225hp
Anything is possible, just need/add $$$$.
Old Dec 20, 2012 | 11:49 PM
AtomicDog's Avatar
AtomicDog
Along with a good bit of TIME to get it all swapped over, installed and tuned, unless you are planning to pay someone to do it for you..
Old Dec 21, 2012 | 12:28 AM
97tn4x4's Avatar
97tn4x4
That motor probally wouldn't be very street friendly lol, that's alot stroke. I've seen a couple and Hughes sells a kit but it's pricey. They are torque monsters though. Your stock trans would **** itself just looking at that motor.
Old Dec 21, 2012 | 10:46 AM
Wombat Ranger's Avatar
Wombat Ranger
I have read for a 4" stroke crank in a magnum a small amount of clearance machining is necessary to clear rod bolts or something. I have also read that anything more than a 4" stroke crank takes a lot of machine work just to prep the block to take the crank. In my personal opinion, a 4" stroke is the way to go for a street driven motor.
Old Dec 21, 2012 | 11:05 AM
Arde's Avatar
Arde
Something else to take into consideration as long as you're going to the trouble and expense of stroking it, rod length to stroke ratio. This is a pretty good explanation.
