Buying a Magnum 360
Old Dec 18, 2012 | 10:05 AM
98Ramboy's Avatar
98Ramboy
Default Buying a Magnum 360
A friend of mine in Northern Minnesota has a Pre 1998 2nd Gen Ram with a 360 V8 that he wants to sell. It doesn't have a transmission but all I'm worried about is the engine. Since I only have the 318, I was thinking about buying it, overhauling it, and upgrading anything I can think of that I'd want to do to the engine, STROKER KIT! After I'd be done, I'd just drop it in, I'd probably have to change the transmission as well...What do you guys think?
Old Dec 18, 2012 | 10:10 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
If you've got the cash, go for it.
Only thing is the PCM, those don't exactly match up. The 360 would run lean with the 318 PCM, but since you're doing a stroker you would need the PCM reflashed anyway.
Old Dec 18, 2012 | 10:18 AM
98Ramboy's Avatar
98Ramboy
Anything I should be looking for in particular?
Old Dec 18, 2012 | 10:21 AM
dodge dude94
Some of the sensors on the intake of the pre-98's are different and so is the flywheel and torque convertor.
Old Dec 18, 2012 | 10:53 AM
kejobe's Avatar
kejobe
The harmanic balancer is different also.
Old Dec 18, 2012 | 10:57 AM
dodge dude94
^But he's going to be entirely replacing the engine, so it would be sensors, flywheel, torque convertor.
Old Dec 18, 2012 | 11:24 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Get a horse!
kejobe's Avatar
kejobe
^^^ Just has to make sure he 360 HB is used and not the 318.
Old Dec 18, 2012 | 11:27 AM
Bear in mind, stroker builds are NOT cheap..... I think Matty had around 5 grand in his, and he wasn't done yet.
The basic engines are exactly the same, some of the peripherals are different.... use the stuff on your truck now, and you will be fine. If you build your 408 internally balanced, you won't need to change the torque converter (right away) either. Keep in mind though, that the added power will eat the stock trans for lunch.
Old Dec 18, 2012 | 11:49 AM
Wombat Ranger's Avatar
Wombat Ranger
Auto's use flex plates, manuals use flywheels.
