Pieces of metal in my differential housing...
Old Dec 22, 2012 | 02:32 PM
Arde's Avatar
Arde
Edit: You will need one of these to remove the carrier, https://millerspecialtools.spx.com/Detail.aspx?id=1103
You can remove it by using a long drift punch in one of the round holes on either side of the diff. housing. Insert the punch into one of the holes in the adjuster and tap with a hammer. Once one side is loose, the other side is also loose.
I made a tool for setting the carrier bearing preload by removing the adjuster and grinding a large nut down to fit it, welding a 30" piece of rebar to the nut and an old socket to the other end.
Old Dec 22, 2012 | 02:57 PM
merc225hp's Avatar
merc225hp
Yep you can make your own tool, nut size or bolt size is 1" should have one on each end so a tq wrench can be used. If you make/have the tool then there is no need for the use of a punch and you need the tool no if's or buts about it.
Old Dec 22, 2012 | 03:13 PM
Arde's Avatar
Arde
I read a lot of different sizes before making mine that's why I took the adjuster out the way I did, so I could make one that fit for sure. Just measured mine, it's a shade larger than 1 3/8", maybe 1 7/16". Also heard about using B body struts but didn't try it. Or was it torsion bars, don't recall.
