Recommended Pan Gasket 46RE
Old Dec 20, 2012 | 10:02 AM
Annihilator_X9's Avatar
Annihilator_X9
Default Recommended Pan Gasket 46RE
My tranny pan is leaking like a ****. Wondering what gaskets you guys go with?
Old Dec 20, 2012 | 10:04 AM
stewie01's Avatar
stewie01
I usually get the set from AutoZone. Comes with two gaskets, one of which won't work (for a different style) and comes with a filter. Works well I think.
Old Dec 20, 2012 | 10:11 AM
Arde's Avatar
Arde
Get mine from O'Reillys, make sure your pan is flat. They tend to distort where the bolts go through.
Old Dec 20, 2012 | 10:32 AM
gertie240's Avatar
gertie240
+1 on the dimpled bolt holes, tap them flat with a small hammer, and torq bolts to spec. Finally learned this after too many years of shade tree wrenching
Old Dec 20, 2012 | 11:39 AM
Annihilator_X9
Awesome tip guys, I wouldn't have even thought to do that.
Old Dec 20, 2012 | 12:17 PM
V10Rampower's Avatar
V10Rampower
Clean the pan really well where the gasket goes to make sure it seals good if not you could get another leak
Old Dec 20, 2012 | 12:19 PM
stewie01's Avatar
stewie01
Pan bolts only require 13ft lbs, not much.
Old Dec 20, 2012 | 12:40 PM
bwdakrt's Avatar
bwdakrt
Use the reusable rubber gasket with the metal inserts around the bolt holes that prevent you from over torquing the pan bolts. Uses no RTV or sealer of any kind. A little more expensive up from but can be used over and over. My tranny has had one from the first fluid/filter change and has been changed 3 times since. Still sealing tight as a drum with no leaks.
Old Dec 20, 2012 | 12:44 PM
Annihilator_X9
Where did you get that kit?
Old Dec 20, 2012 | 01:14 PM
bwdakrt's Avatar
bwdakrt
My tranny man had it on his shelf but can be bought at about any parts store.
