transfer case swap 98 1500
Old Dec 24, 2012 | 02:09 PM
Tommy Francetic's Avatar
Tommy Francetic
Default transfer case swap 98 1500
i have 98 1500 and my tcase is going. so i do lots of wheeling so i was thinking can i put a tcase from a 3/4 or 1 ton tcase in my 1500 and if so wha tcase and what year of tcase and i am going to do dana 60 convertion in the summer and i have heard that tcase from a 98 3/4 will bolt right in.or is it worth just rebuilding my tcase?
Old Dec 24, 2012 | 04:37 PM
Go for the 241D case. (LD or HD, either would be an improvement.) You can find them in 98 and up 3/4 and one ton GAS trucks. Gotta be a v-8 though, the 10 uses a different trans output shaft. (I think)
Old Dec 24, 2012 | 05:21 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Only problem with the 241HD is that it has a PTO shaft on it.
Old Dec 24, 2012 | 06:17 PM
That was an option. Most just have a cover plate where the PTO drive would go. Mine doesn't have the PTO.
Old Dec 24, 2012 | 06:23 PM
dodge dude94
Doh! Yep, looked through the 99 brochure again and it says that it's PTO ready. So it wasn't "optional", it has the ability to, you just have to buy the PTO unit.
Old Dec 25, 2012 | 02:12 AM
Tommy Francetic
thx guys
Old Dec 25, 2012 | 11:17 AM
Wombat Ranger's Avatar
Wombat Ranger
I am almost 100% sure that v10/diesels used a 23 spline output on the back of their auto's, just like the gas transmissions.
Old Dec 25, 2012 | 11:18 AM
Entirely possible... I thought I remembered reading somewhere that the shaft was larger diameter on the diesels, and 10's??
Old Dec 25, 2012 | 11:23 AM
Wombat Ranger
With the stick's they had a 29 spline output, but the auto's use the same sized 23 spline. Just did a double check. Inputs are definitely bigger, maybe that's what you're thinking.
Old Dec 25, 2012 | 03:27 PM
Could be.
