supercharged 2001 Dodge Ram
Old Dec 25, 2012 | 01:57 AM
Jjgerhart's Avatar
Jjgerhart
Default supercharged 2001 Dodge Ram
looking for input on an idea. trying to put a supercharger off a Buick Riviera with the 3800 v6 into my 01 Ram with the 5.9 Magnum.
think I'm wondering is if the supercharger would flow enough cfm for the v8.
Old Dec 25, 2012 | 09:37 AM
With the right pulley it probably would, trouble is, you would be running it well beyond it's design parameters, and it would most likely grenade fairly quickly. Not to mention trying to even mount the crazy thing.....
At one time, either vortec, or paxton made a bolt on centrifugal supercharger for the Rams, might still be able to find one used somewhere.
Old Dec 25, 2012 | 05:06 PM
Jjgerhart's Avatar
Jjgerhart
Looking into it jus for a fun lil offroader fabrication is no problem. Jus want a new project to screw around with plus kinda on a budget lol
Old Dec 25, 2012 | 08:40 PM
stewie01's Avatar
stewie01
Not looking to bust ***** or anything but budget, Ram, and supercharger can't exist in the same sentence.
It's like the Irish Butter my grandmother brought that has no alcohol in it... It just can't happen!
Old Dec 27, 2012 | 11:13 PM
AtomicDog's Avatar
AtomicDog
Bolt-on Supercharger kits are available for the '94 - '01 Rams. Here is an example:
http://www.fasthemis.com/procharger-...1996-2001.aspx
Old Dec 27, 2012 | 11:42 PM
Wombat Ranger's Avatar
Wombat Ranger
^^ And so affordable!
Don't forget to build a nasty trans to go behind it. Not that this project will ever happen...
Old Dec 27, 2012 | 11:51 PM
AtomicDog's Avatar
AtomicDog
There also seems to have been a turbo setup available on the Ram Indy Pace truck edition. Happened to trip over it during some recent google searches..
Old Dec 28, 2012 | 01:26 AM
jasonw's Avatar
jasonw
Site Moderator
Turbo or Supercharger, like Wombat said, don't forget the transmission. It can barely handle the 5.9L V8 as it stands over a long duration, let alone something with substantially more power like what a supercharged/turboed engine would do.
Old Dec 30, 2012 | 02:48 PM
Jjgerhart's Avatar
Jjgerhart
I was doing some more research and I found that I could run dual of the same supercharger and just make a manifold to handle the boost to go into each side of the v8. and budget and supercharger can go in the same sentence looking into it and it can all go together. Out under 1000 dollars
Old Dec 30, 2012 | 03:03 PM
Derick C.'s Avatar
Derick C.
You would for sure need a good hd trans build. My stock rebuilt trans did not last long behind my new 408, the trans only had about 40k on it when the motor went in and a month later the trans was toast.
