transmission numbers and identification
Old Aug 20, 2021 | 07:15 AM
  #71
Originally Posted by bigchief187
sorry again!! It came out of a 1999 Dodge Durango
Probably have to change the governor pressure stuff then. Some of it changed between 99 and 00. Should be able to transfer it from the old to new trans. There is a mounting bracket you need as well. (for the electronics.)
Old Aug 20, 2021 | 08:24 AM
  #72
bigchief187's Avatar
bigchief187
thank you for your time. I will see if it will work! Thanks again
Old Nov 8, 2021 | 06:11 PM
  #73
mau.tico's Avatar
mau.tico
Hello guys, I have been trying to identify mine...
The code is PK511184332443 0164 and the housing is 238-2 C. I have not been able to identify it.
From the outside is identical to a 47RE, I do not know from which car it belonged to since I picked it from a shop who didn't know.
It has a 8 PIN connector so I know it is an RE.
My PAN gasket looks like this:
Thanks.
Old Nov 8, 2021 | 10:41 PM
  #74
mau.tico's Avatar
mau.tico
*deleted comment*
Old Nov 8, 2021 | 10:44 PM
  #75
mau.tico's Avatar
mau.tico
NVM guys, I just queried the guys from mmerlinn and they told me it is a 47RE built on 22 Aug 1995.
Old Dec 8, 2022 | 05:25 PM
  #76
drivnadodge's Avatar
drivnadodge
Default Does the 064-10 swap with 067-6
I went to a junkyard and picked up the transmission from an identical truck, which is a 99 dodge ram, 2500 2wd. After I swapped the transmissions, I noticed a slight difference with the housing. However, I turn the key and get nothing engine will not start, so I’m wondering if it is a problem with compatibility
Old Dec 10, 2022 | 08:43 AM
  #77
Shouldn't be a problem. Is the neutral safety switch plugged in? Next question would be, does it work?
Old Jan 31, 2023 | 03:24 PM
  #78
jasonleininger82@gmail.com's Avatar
Default 46re or 47re 1996 dodge 2500 5.9l gas r.w.d automatic tranny
[I have 1996 dodge 2500 5.9l gas r.w.d truck automatic tranny. Which tranny do I have or can I find out by vin. Do I have 46re or 47re
QUOTE=Hawkeyefan;2932460]OK first off this is going to take me a little while to get all this on here. I'm going to put every thing I have about matching up transmission numbers. I got some of this info from a family member who works at the transmission plant in Kokomo Indiana,and the rest from different places. A few things to remember when looking for another trans. In mid 99 they changed some of the electronics.96 and up A500, A518, and A618 use the same governor pressure solenoid. 96-early 99 A500,A518,and A618 use the round metal pressure sensor or transducer as some call it. Late 99s and up use the black plastic 1.
96 -early 99s use the same OD & lockup solenoid. late 99s and up use the same OD & lockup solenoid. 78 -98 uses a round black neutral safety switch with 3 pins.For 99s they changed the neutral switch to a rectangular white plug with 3 pins. In 2000 they changed to a 5 pin big plastic switch
If you look above the pan on the drivers side there will be some numbers stamped on the case most of the time they start with PK. The next 8 numbers are the part# for that transmission. Also if there's fins above the rear servo it's a A618. Diesel and V10s have a moon shaped cut out at the bottom of the bell housing for a bigger torque converter.
4X4 models
96-99
1500 & 2500 5.2L & 5.9L 46RE
2500HD & 3500 5.9 47RE
4864243
52118427
52118432
52119516
52119517
52119527
52119541
52119820
52119823
V10 8.0L 47RE
52118434
52118436
52119518
52119539
52119827
5.9L diesel 47RE 1997-1999
52119519
52119542
52119828
2000-2002
5.2L & 5.9L 46RE
1500 MODELS
52119844
52119846
2500 & 3500 MODELS
5014772AA
5014770
52119844
5014772
V10 8.0L & 5.9L DIESEL 47RE
52119851
I will add more when I get time later. Hope this helps some1.[/QUOTE]
Old Dec 6, 2023 | 12:28 AM
  #79
Bal_258's Avatar
Bal_258
I have 046-1 is that a RE
Old Dec 6, 2023 | 12:30 AM
  #80
Bal_258's Avatar
Bal_258
Default Please help
Is 046-1 a RE it’s 2000 and I want to put it on my 2001 any suggestion
