Starting problems
Old Dec 26, 2012 | 09:18 PM
byronpen's Avatar
byronpen
Default Starting problems
Here is my last post
Ok my 99 1500 5.9l truck, Dose not like to start, I have to push down the gas pedal and hold it and crank the truck for a few seconds for her to fire. Then the hole Truck shakes. But when I let go of the Gas and it will die. I have to keep on the gas and get the truck moving for the truck to stay running, And other time it will start like normal. with no problems.
Could this be a grounding problem or something else.
my family calls this a money pit, But I will never give
up on this truck!!!
Thanks everyone have a great day.
I was told to replace
IAC sensor
DiD that no change. Now that its cold it wont stay started.
Any New Ideas people?
Old Dec 26, 2012 | 09:24 PM
dlyter09's Avatar
dlyter09
Did you have the battery disconnected when you replaced it?
Old Dec 26, 2012 | 09:30 PM
byronpen's Avatar
byronpen
ASD Relay?
Old Dec 26, 2012 | 09:57 PM
If it were the ASD relay, it wouldn't start at all.... and gas pedal position would make zero difference. I would look at the throttle position sensor, and/or the engine coolant temp sensor. TPS you can test with a multi-meter, ECT you need a scanner to see what it thinks when the engine is cold. Might check the connector in any event, should be right near the thermostat housing.... make sure it is plugged in tight.
Old Dec 26, 2012 | 11:30 PM
greanbeans's Avatar
greanbeans
I think that's my problem on mine only its good if its cold and hates being warm
Old Dec 26, 2012 | 11:31 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
^Your issue sounds like the pre-cat 02 sensor going out on you.
Old Dec 27, 2012 | 08:05 AM
byronpen's Avatar
byronpen
When I replace the IAC sensor the battery was still connected.
Old Dec 27, 2012 | 08:06 AM
byronpen's Avatar
byronpen
TBS Sensor have been replace.
Old Dec 27, 2012 | 08:07 AM
byronpen's Avatar
byronpen
is there a by pass for the 02 sensor. as its really cold. I dont want to lay in snow. LOL
Old Dec 27, 2012 | 08:14 AM
dodge dude94
Nope.
