cold start woes
Old 01-03-2013, 09:35 PM
95BIGRED's Avatar
95BIGRED
95BIGRED is offline
Default cold start woes
Yesterday after work I got into to my truck and started it, immediatly I noticed it was running really rough. It was rocking the truck it was so bad. Got out popped the hood and it sounded like there was a vac leak, checked around didn't find anything loose and noticed the the noise was coming from my intake. Was it warmed up everything went away and felt like the beast it usually is. This morning same thing rough idle loud sucking noise till it go warm. Today after work same thing. while sitting there waiting for it to get warm I played with the throttle a bit, took it up to 1500 rpm and try to hold it, nope went down a couple hundred came back up and repeat. Let off the throttle and it almost died. I live in salt lake city, we've been in the low teens high singles. Please help im worried bout my baby. Thanks in advance
Old 01-03-2013, 09:44 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,390 Likes on 3,130 Posts
Got a scanner that can read real-time data handy? See what your PCM thinks engine temp is at cold start. It should be REALLY close to ambient.
Old 01-03-2013, 09:48 PM
95BIGRED's Avatar
95BIGRED
95BIGRED is offline
I don't and don't know anyone up here who does
Old 01-03-2013, 09:50 PM
HeyYou is offline
That may be a problem.....
Is it trying to flood out? Or, just RLS?
Old 01-03-2013, 09:52 PM
95BIGRED's Avatar
95BIGRED
95BIGRED is offline
Im not sure it smells it has a real lopey sound while this is going on. My buddy suggested maybe the iac is gummed up but I just cleaned the hell outta it a few months ago
Old 01-03-2013, 09:53 PM
HeyYou is offline
What does it smell like?
Old 01-03-2013, 09:56 PM
95BIGRED's Avatar
95BIGRED
95BIGRED is offline
Its a real strong exhaust smell idk how to describe it. It usaullay smells a bit but I expected that with how open the exhaust is.
Old 01-03-2013, 09:58 PM
HeyYou is offline
I would be tempted to just replace the temp sensor the PCM uses, and see if that doesn't improve it's attitude any...... (it's the two wire sensor on the drivers side of the thermostat housing.)
Old 01-03-2013, 10:01 PM
95BIGRED's Avatar
95BIGRED
95BIGRED is offline
Alright ill check into that this weekend to damn cold to work on it now and I work tomorrow thanks for the quick response ill keep updating if anything changes
Old 01-03-2013, 10:04 PM
HeyYou is offline
Yeah, let us know. It might be as simple as a loose connector on the sensor too.... check that before spending money.
Quick Reply: cold start woes
