Ripped wires!! Help!
Old Jan 4, 2013 | 08:22 PM
redcynik's Avatar
redcynik
Default Ripped wires!! Help!
hi guys i messed something up. i have a dodge 1500 1997 laramie ram. i took out a broke aftermarket radio and in the process ripped a
connection that was behind it. i still have the connection nothing was plugged into it but it had the pink wire, black and green and two other wires into it
it was a 4 prong connection. but as soon as i ripped it out the cab roof push lights are out and now there is no power to
the radio. should i reconnect the ripped wires to the 4 prong connector? or is it a fuse? or should i just install new radio and see what happens?
Old Jan 4, 2013 | 08:50 PM
kejobe's Avatar
kejobe
Fix the wires.
Old Jan 4, 2013 | 08:53 PM
grover2044's Avatar
grover2044
^^ agreed, and then check for a blown fuse...
Old Jan 4, 2013 | 09:01 PM
Ziggy2112's Avatar
Ziggy2112
both. if you stripped the wires, and they touched each other, or against the ground of the radio that would cause a dead short, and likely blow a fuse or even two...dependending on where they went. no matter what, put electric tape over those exposed wires! .....or in the words of Yoda
Suffer the same problem you will..
