control arm cam bolt differences
Old Jan 12, 2013 | 03:22 PM
  #21
dlyter09's Avatar
dlyter09
the sawzall and grinder should be all you need
Old Jan 12, 2013 | 04:08 PM
  #22
redneck_ram's Avatar
redneck_ram
i hope so, ill probly go get a sawzall blade tomorrow. hopefully itll work.
Old Jan 12, 2013 | 04:17 PM
  #23
Blow the head/nut off the bolt with the grinder.. since you don't have a torch.... leave the center part of the bolt in there, since you aren't going to re-use those control arms, no point going to a lot of effort to get them all out.
Old Jan 12, 2013 | 04:20 PM
  #24
redneck_ram
i was gonna cut in between the axle bracket and the control arm. figured that would be easier.
Old Jan 12, 2013 | 04:29 PM
  #25
If you have enough room in there for your sawzall blade, GO FOR IT!
Old Jan 12, 2013 | 04:59 PM
  #26
redneck_ram
yep, theres plenty of room in there, just gotta burn the rubber bushing a bit. haha
Old Jan 12, 2013 | 09:56 PM
  #27
Wh1t3NuKle's Avatar
Wh1t3NuKle
Actually, since I just recently did this, I'd recommend using sawzall last resort. Reason being that the bushing is right up to the bracket surface. So you'd be cutting that for a good time.
I'd suggest you get a portable bandsaw. Rent it if possible from home center. Blade is thin enough to get between. Other way is tried and true hack saw, with a good blade on it.
I hope you have better luck burning the bushing. I used a plumber propane torch...not a budge. Oxy/Acet torch...fosho!!
