Missing when warm....
Old Jan 12, 2013 | 10:18 PM
UnregisteredUser's Avatar
UnregisteredUser
With those symptoms I'm scoping the ignition, testing compression (and leakdown if compression is unbalanced, natchrully), and inspecting exhaust valve springs. It sounds a lot like a burnt exhaust valve, but it could also be a coil heading south or a flaky CPS producing a soft signal (crappy rise and fall times, low peaks, that kind of thing).
Old Jan 13, 2013 | 07:57 AM
Coil was replaced as well last summer... I think.... (it was replaced, just not sure of the time frame.) I have another one yet, as that didn't fix the problem I was having then either......
I am thinkin it's time for a compression test..... but, that is probably going to tell me it's new motor time........
Old Jan 13, 2013 | 08:41 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Check the fluid level in your Turbo Encabulator.
Old Jan 13, 2013 | 08:55 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
is it smoking at all when warm?
Old Jan 13, 2013 | 09:26 AM
Smokes on the first drive of the day, for about a half mile. Yes, I have excessive oil consumption..... about a quart every hundred, hundred and fifty miles or so. The plugs are relatively recent.. but, I guess I will pull them, and see what they look like.
Old Jan 13, 2013 | 11:03 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
holy smokes on the oil consuuuuming!
In your first post you mention oil fouled #8, then you tested with front O2 out that showed improvement (partially). Any thought to clog cat contribution to this?
Old Jan 13, 2013 | 11:09 AM
westgbwoy's Avatar
westgbwoy
Timing ??
Old Jan 13, 2013 | 11:16 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
A clogged cat might not be causing the miss. With that much oil consumption, I'm thinking worn rings and/or worn valve stem seals.
Old Jan 13, 2013 | 12:13 PM
Yeah, valve seals are most certainly toast. The cat was hollowed out before I got it. The oil consumption has improved since the plenum repair... (used to be a quart every 50 miles...) but, the engine only smokes for about a half mile on the first drive of the day.... no evidence after that. Given the sheer volume of oil I am going thru, I would think it would smoke like a diesel..... but no...
I am guessing that it is getting on toward time (if not past time..) for a different motor. I think come income tax, a rebuilt unit is going to be part of the plan.
Old Jan 13, 2013 | 12:49 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Heck with that. Yank that puppy and rebuild it yourself.
