Missing when warm....
Old Jan 13, 2013 | 01:13 PM
  #21
stewie01's Avatar
stewie01
4BT Swap!
Old Jan 13, 2013 | 03:36 PM
  #22
h3lzsn1p3r's Avatar
h3lzsn1p3r
time to drop a 572 hemi in it
Old Jan 13, 2013 | 03:37 PM
  #23
UnregisteredUser's Avatar
UnregisteredUser
I am guessing that it is getting on toward time (if not past time..) for a different motor. I think come income tax, a rebuilt unit is going to be part of the plan.
When the new one hits 120,000 miles, put new valve seals in it.
Old Jan 13, 2013 | 04:09 PM
  #24
gdstock's Avatar
gdstock
Maybe I should take a fuel sample......
I get gas at two different stations, a BP, and a speedway.... Think I got gas at BP last time.... I am going to need to get gas tomorrow.... maybe I will toss in some 89 from a good station.
Originally Posted by redneck_ram
just for shlts and giggles, throw in some dry gas, see if that helps. could be part of the problem. BP had a problem with their gas a while back. it was gelling up in peoples tanks and lines, destroying the engine in the process.
I thnk BP got saltwater in their gas some time back.....heehee....instead of fresh water!
Originally Posted by stewie01
4BT Swap!
Yeah, something to use up some "spare time!"
HeyYou, do you have a scanner that can monitor O2 readings real time? That might provide some insight. Seems strange it only does it when hot and not cold.
Old Jan 13, 2013 | 06:58 PM
  #25
Some interesting options there.....
Unfortunately, I do not have a scanner..... the one that used to be available to me got sold. (he retired, and sold off a bunch of his really cool tools.... scanner, brake lathes... etc. I was bummed.)
So, driving home from work today, I watched the temp gauge, and monitored how the engine was running. Smooth as glass right up until the temp gauge passes the halfway point between 130, and 200, then it starts to miss and buck.... It has GOT to be a sensor somewhere..... just can't figger out which one.....
Old Jan 13, 2013 | 08:18 PM
  #26
Gary-L's Avatar
Gary-L
Veteran: Navy
IAT? Coolant Temp Sensor?
Old Jan 13, 2013 | 09:01 PM
  #27
gdstock's Avatar
gdstock
What color is the truck?
Brig it down here and we'll hook it up and see....
Old Jan 13, 2013 | 09:17 PM
  #28
merc225hp's Avatar
merc225hp
Unplug the 02's from the harness see what it does. Start with the back one.
Old Jan 14, 2013 | 08:26 AM
  #29
Front O2 is unplugged. No difference.
Is the resistance value on the ECT for the PCM linear? Or does it make a jump around 150 or so?? I seem to remember seeing something along those lines at one point...... maybe?
Old Jan 14, 2013 | 05:22 PM
  #30
Well, took a couple suggestions from this here thread.... (thanks guys.) Had a service call today, so, went and put 40 bucks worth of 89 octane gas from shell in, and a bottle of gas dryer..... went for a drive, ran fine, for the most part... it did miss a little bit again about halfway thru the trip, (which was only about 12 miles one way) but, it got over it fairly quickly. This leads me to believe that it is time to drop the tank, and flush the entire fuel system, and see what kind of stuff I find in my gas.... But, I think I will run it down to at least a quarter tank before doing that......
Also found where my coolant had been going..... seam on the radiator is leaking pretty good now. Taking it to the shop tomorrow to replace it. (already got the new one, and also, some new A/C Delco plugs to install...)
We shall see if this permanently solves the problem.
Thanks Guys!
