Missing when warm....
Old Jan 14, 2013 | 05:23 PM
  #31
SirHarold's Avatar
SirHarold
How do I start my own thread?
Old Jan 14, 2013 | 05:32 PM
  #32
On the main page of this forum, there is a button "New Thread". it's in the upper left, below the titles and such.
Welcome to DF.
Old Jan 24, 2013 | 07:12 AM
  #33
Rayburn91's Avatar
Rayburn91
Im having close to same symptoms after changing my crank sensor did you get this fixed? my truck was running great before i changed my clutch, broke the sensor putting trans back in bought a new sensor from autozone now runs horribly missing and popping i have checked my connections and wires for any broken or bare spots and just cant figure it out
Old Jan 24, 2013 | 08:16 AM
  #34
Mine seems to have been a combination of failing sensor, and bad gas. For yours, I think your problem is the sensor... what brand did you get?
Old Jan 24, 2013 | 02:39 PM
  #35
Rayburn91's Avatar
Rayburn91
i think its duralast not 100% but it came from autozone with lifetime guarantee so I'm gonna pull it and exchange it and see if anything changes
Old Jan 24, 2013 | 02:51 PM
  #36
Mine is a BWD unit... and I think I still have some minor missing issues... but, can't swear to it one way or the other. (might just be bumpy roads that I am feeling, as my 3/4 ton suspension is quite stiff....)
These trucks are notorious for not liking aftermarket sensors in key places, crank sensor being right at the top of the list.... I wanted to get a delphi unit, (for almost twice the price of the BWD unit...) but, I would have had to order it, and unfortunately, didn't have the time to wait. Replacing your duralast with another one probably won't make any difference at all. Especially considering yours started it's behavior with the crank sensor change....
It's warmer out today, though still pretty chilly, we shall see how the truck runs....
Old Jan 24, 2013 | 02:59 PM
  #37
Rayburn91's Avatar
Rayburn91
So where do you recommend i get the sensor from. I was looking at it again a min ago for the hundredth time and i think i have an exhaust leak on the drivers side where the manifold meets the y pipe could this be adding to my issues?
Old Jan 24, 2013 | 03:03 PM
  #38
Leak probably doesn't help.....
Dealer sensors are 'the best', of course, they ain't precisely cheap either..... I think they are close to 200 bucks for the crank sensor...... if you can, find the delphi unit. (it was like 80 something at Advance... might have to order it) Not sure who makes the stock dodge unit. (might even BE delphi.....)
Old Jan 24, 2013 | 03:04 PM
  #39
Rayburn91's Avatar
Rayburn91
Ok cool thanks for the advice ill check into it
Old Jan 24, 2013 | 03:17 PM
  #40
Wow, I sit corrected. Local dealer only wants 81 dollars for it.... too bad they don't have one on the shelf, and they are on backorder...... I see a new one coming in my future.
