no balls
Old Jan 16, 2013 | 11:58 PM
  #51
GTXpress's Avatar
GTXpress
Right. Im saying it was all the spinning of the tires that burned up the clutches and material in your trans. I hate auto trans.
Old Jan 17, 2013 | 11:18 AM
  #52
duckslayer5032's Avatar
duckslayer5032
I don't think so, I was saying it was able to, didn't say I did it all the time
Posted from Dodgeforum.com App for Android
Old Jan 17, 2013 | 07:47 PM
  #53
redheadhunter21's Avatar
redheadhunter21
If you haven't unplug negative battery cable, turn on headlights, then jump up and down three time while praising dodge gods. Then reconnect negative cable put truck in 1st gear and let er rip. Should fix your problem. Put it back in drive and see if it goes through all four gears including torque converter lockup
Ps. Headlights will most likely not even turn on but leave the switch on while jumping around
Old Jan 17, 2013 | 09:18 PM
  #54
duckslayer5032
how bout we get serious inquiries on what it could be instead of people making a sad attempt at being funny people post on here to get help no read you sarcastic pathetic attempts at making jokes
Old Jan 17, 2013 | 09:30 PM
  #55
He was being serious...... with a bit of humor.
Give it a shot. Basically, what he is suggesting is forcing the PCM to forget everything it knows about how the engine runs, and relearning it. Certainly can't hurt.....
Old Jan 17, 2013 | 10:23 PM
  #56
GTXpress's Avatar
GTXpress
Hey i am just sayin man. Picture in your sig suggests it too. The auto trans in these trucks are weak. Thats known. Try these things they are telling you, but its sounding like a trans issue that is going to get worse until you take it apart and replaced what has been damaged. I dont understand auto transmissions, which is why i buy manuals. Sorry i know Im not helping...
Old Jan 18, 2013 | 01:08 PM
  #57
redheadhunter21
If you haven't tried it don't knock it, like heyyou said it will reset the PCM and clear any codes.
If said truck had a tranny problem related to computer this can help. You have a transmission harness connector that is prone to getting water in it. It can cause different things from the tranny. Water gets everywhere when offroading I know this as a fact.
Old Jan 18, 2013 | 07:02 PM
  #58
duckslayer5032
did the pcm reset truck running same way, trans fluid smelling little bit more burnt, taking it Monday to the shop for jasper to warranty it
