front steering u joints
Old Jan 14, 2013 | 05:52 PM
  #21
jconlin's Avatar
jconlin
Thanks for all the advice guys
Old Jan 14, 2013 | 07:08 PM
  #22
Darren270's Avatar
Darren270
I replaced my drivers side u-joint about 6 months ago. My experience pretty much mirrors everyone elses. The most difficult part was getting the axle nut off. I dosed it in PB Blaster for several days prior, but didn't seem to make a difference. The socket for the axle nut I purchased at Sears. Trying to bust the torque on that nut with just a breaker bar proved impossible until I found a 4 foot length of steel tubing. As soon as I slipped that on to the breaker bar the nut came right off.
The only other tool I bought was a bearing puller from Harbor Freight that I used to get the hub off. Using that, the hub pulled right off with little effort. Replacing the u-joint itself was pretty straightforward. It took some muscle but wasnt that bad.
Once the new u-joint was installed, it only took me about 15-20 minutes to put everything back together and take it for a test drive. It probably would have taken less, but like a moron I put the heat shield on backwards and had to take the hub back off to flip it.
Old Jan 14, 2013 | 09:18 PM
  #23
h3lzsn1p3r's Avatar
h3lzsn1p3r
i do no seperate the hub from the axle it saves 10 mins like that
Old Jan 14, 2013 | 09:24 PM
  #24
jconlin's Avatar
jconlin
Do I just leave the bolts for the hub in? The three 12 point ones? Please explain
Old Jan 14, 2013 | 09:41 PM
  #25
He means don't take the axle nut off, pull the axle and the hub together. Hub HAS to come out to change that joint.
Old Jan 14, 2013 | 09:50 PM
  #26
jconlin's Avatar
jconlin
Okay, so maybe I won't have to screw with that rediculous nut after all
Old Jan 15, 2013 | 09:22 AM
  #27
h3lzsn1p3r's Avatar
h3lzsn1p3r
it is alittle more auqward doing it with the hub on i am used to it because i am a mechanic for dodge
Old Jan 15, 2013 | 10:54 AM
  #28
Wh1t3NuKle's Avatar
Wh1t3NuKle
Which means you have tools and tables.
Jerk
Old Jan 15, 2013 | 11:57 AM
  #29
stewie01's Avatar
stewie01
Jerk
You sure? Dodge dealer's shop in Fitzgerald, Ga had tables in the middle but I didn't see 1 single tool or piece of machinery besides a desktop computer.
Old Jan 16, 2013 | 10:03 AM
  #30
h3lzsn1p3r's Avatar
h3lzsn1p3r
Jerk
i use sockets and a hammer like every one else but i have a vice bolted to my tailgate that i can use when not in use for on the trail and i do it the same whay then 2
