Torque converter not locking?
Old Jan 15, 2013 | 09:41 AM
97tn4x4's Avatar
97tn4x4
Default Torque converter not locking?
Ok so the other night I was driving home and the truck just didn't feel right, and I noticed my rpms higher than normal. I stopped and cut the od switch off and took off and counted the shifts and didn't notice the tcc lockup. I stopped again cut it back on then off again, took off again and then it locked up, cut the switch on again and all was good. Now this morning on the way to drop the kid off at school all was good, on my way back it again wouldn't lock up. Nothing I could do would make it lock. I pulled out the trusty sct and I'm getting a p0734 which appears to be a 4th gear ratio incorrect or something. The trans is rebuilt with maybe 10k on it and I doubt it's that high honestly. I'm fixing to go the the dr and Im gonna clear the code and see what it does now. I'll report back and any help would be great.
Old Jan 15, 2013 | 09:54 AM
stewie01's Avatar
stewie01
Might have a look here:
https://dodgeforum.com/forum/2nd-gen...uble-code.html
04-08-2012, 12:55 PM
master tech
Site Moderator
Dodge Forum Moderator
Garage is empty, add now
Vehicle: Mits P/U , Dodge avenger(1996) .
If you had other codes like, P0720, P0715 and fault after shift codes. I would say sensor, But if you are just getting gear rario error in 4th, The plate on the side of the valve body may have snap off some screws and the plate is bending. How is the fluid condition?
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Have you checked your fluid?
Old Jan 15, 2013 | 09:55 AM
P0734 Gear 4 Incorrect Ratio
Well then, that is certainly odd. Not like your trans can change the gear ratio....
Have a look here.
Old Jan 15, 2013 | 10:01 AM
97tn4x4's Avatar
97tn4x4
I do have 4.88's and haven't changed my speed sensor on the transfer case and my speedo is way off lol, but that doesn't change rpms. I'll go check the fluid when I leave and report back.
Old Jan 15, 2013 | 10:41 AM
97tn4x4's Avatar
97tn4x4
Well the tcc still isn't locking, the fluid is bright red and is full, it may be just a hair over but it's full. I also noticed I used to have a slight wine at highway ish speeds. I don't seem to notice that anymore so that's not good. My next day off I think I'm gonna bite the bullet and drop the pan and see what's hiding in there.
Old Jan 15, 2013 | 10:46 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I think something is indeed going awry buddy. Slipping clutch plates comes to mind.
Old Jan 15, 2013 | 10:47 AM
stewie01's Avatar
stewie01
Sounds like a good idea.
Some debris on the magnet is normal, lots of metal isn't.
The OP in the link I provided took it to a shop I'd guess, and was in for a rebuild...
Old Jan 15, 2013 | 10:55 AM
97tn4x4's Avatar
97tn4x4
Mine was rebuilt less than 10k ago with a tad stronger than factory set up by a very reputable shop. I don't know what it could be but hopefully it's something I can fix. I dropped the vb in my Grand Cherokee which is basically the same so I'm no stranger but it's cold and I don't really wanna have to lol. What's throwing me off is it shifts good and crisp the damn TC just won't lockup.
Old Jan 15, 2013 | 11:33 AM
If it's still under the warranty from the rebuild, go see them.
Old Jan 15, 2013 | 12:48 PM
97tn4x4's Avatar
97tn4x4
I wish it was, but it's been 2 years and the warranty was only a year. I thought I stopped hearing the whine but it's still there so I may drop the pan Thursday. This plate that was brought up that's on the vb. Is that something I can fix?
