Buying used Ram. What to look for?
Old Jan 16, 2013 | 02:44 AM
Red03Dak's Avatar
Red03Dak
Default Buying used Ram. What to look for?
Ok so I sold my '03 Dakota in order to move up to a fullsize Ram. I've been looking around on craigslist and have found a couple I like and I'm going to go check them out. My question is, what are some specific things to look for on these year Rams? I have a moderate knowledge of vehicles so I know the basic stuff to look for...but what are some of the SPECIFIC problems 2nd gen Ram's have? Any help is appreciated. Thank you.
Old Jan 16, 2013 | 06:48 AM
tbone360's Avatar
tbone360
Leaking plenum and fragile transmissions and even more fragile dash board.
Old Jan 16, 2013 | 07:09 AM
dhvaughan's Avatar
dhvaughan
look for an 00-01 offroad edition. 2 inch factory lift, 4.10 gears, tow hooks.
expect to pay an extra $1000 for it.
Old Jan 16, 2013 | 07:56 AM
Try to get a, I believe, 99 and up. Those have the third door and also the dash has a few more storage compartments or at least bigger storage compartments. Check for repaired intake plenum (read the plenum sticky) and be prepared for trans troubles if not already addressed.
Old Jan 16, 2013 | 08:38 AM
stewie01's Avatar
stewie01
3rd door? Mine gas 4, hence quad cab
Old Jan 16, 2013 | 10:29 PM
Obiejuankinobie's Avatar
Obiejuankinobie
Rust along door bottoms and rear under small doors.
Old Jan 17, 2013 | 12:00 AM
GTXpress's Avatar
GTXpress
Look for a manual transmission and youll be set. Everything else is regular used car stuff.
Old Jan 17, 2013 | 01:38 AM
ReadRam's Avatar
ReadRam
99 thru 01 supposedly have beefier front end suspension, for improved braking....handling etc...according to Edmunds review, and I read it somewhere else too. I know my 99 has a bigger a/c compressor than my ex 94. 98 is when they changed dash design and added passenger side air bag. Check how much slop in steering wheel...worn out gearbox. If oil pressure gauge never goes over the 40 mark, I would be thinking sludged up from lack of oil changes. Good luck!
