Fuel Pump
Old Jan 17, 2013 | 12:13 PM
goalcrasher13's Avatar
goalcrasher13
allof thoughs were done in the last 6 months. I just picked up a new front O2 censor ill put it in tonight. when I checked the fuel pressure I left the gauge on for a while and the psi went down to like 2psi shouldn't it keep a constant pressure even if the truck is off?
Posted from Dodgeforum.com App for Android
Old Jan 17, 2013 | 12:55 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Fuel pressure will bleed off. That's why, with FI vehicles, the key should be turned to the "ON" position and the driver should wait until the fuel pump whine ceases before attempting to start the vehicle.
It could be a failing coil pack, dirty IAC, or faulty throttle throttle position sensor.
Old Jan 17, 2013 | 05:25 PM
goalcrasher13
ok well the coil pack is new but I have not checked the iac or the tps so I will do that when I get home. any other things I should maybe check out?
Old Jan 17, 2013 | 09:13 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
There's a DIY that pertains to cleaning the IAC. Check that first.
Old Jan 17, 2013 | 10:54 PM
goalcrasher13
I think I found the problem! my brand new set of wires are crap. I stayed a fine mist from a squirt bottle on the wires and almost every one is bad. my coil wire must have 30 cracks in it! its like a light show under my hood!
Old Jan 18, 2013 | 08:59 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Winner, winner, chicken dinner!
Good to see you took the time to trouble-shoot rather than swapping out parts and hoping for the best.
Old Jan 18, 2013 | 10:12 AM
goalcrasher13
Anyways now that I figured that out I'd still like to change my fuel pump out because it old and I don't trust it anymore. so I was wondering if anyone has ever changed there truck over to a external fuel pump?
Old Jan 18, 2013 | 10:16 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
I wouldn't do that. Leave it until it fails and then replace it with the proper unit.
Old Jan 18, 2013 | 10:31 AM
Hahns5.2 has. He even has a return style system. Don't recall if the pump is external or not....
