About to blow the truck up!!!
Old Jan 21, 2013 | 10:49 PM
gdstock's Avatar
gdstock
Originally Posted by oxymoron29
Not every problem is due to the MFing plenum ffs. Jeezus.
Have you checked for spark on all 8 lately? Fuel? Sounds like guy who did your dizzy phukt something up if it ran like crap shortly after. Take a timing light to it and check that it's not completely out of whack. Check the essentials then ask for help.
Someone needs to chill. Plenum is a reasonable question to ask!
Originally Posted by Matt Nickerson
No...But it takes 3 minutes to check it, and it's the source of many problems including symptoms such as the OP's spark knock and idle problems.
Partial check, but reasonable indicator, depending on amount of oil!
At last, someone that has half a clue and doesn't just regurgitate the same BS over and over again. I've been lurking here long enough to know that the plenum gasket is the end-all-be-all of every issue known to man on these trucks.
Lurking must not equal learning....lol.....
Op sorry off topic here, I apologize for that.
Ok the youngest motor for these trucks is now 11 years old, so the pcv system has been putting oil in the intake for that long. Next as this is a open plenum intake there are air vortexes inside the intake that will pick up that oil and deposit it in the same spot all the time, hence the oil pooling areas. There is only one way to tell if the plenum gasket is leaking and that's to remove the intake and inspect it. HeyYou is right the leaking gasket will play havoc to certain parts of the motor. To me it's a 50/50 call if the gasket is leaking.
PCV may be a greater influence on thse than most realize. After putting a catch can between my PCV and intake, I dump about 4 - 5 teaspoons of oil each 3000 mile oil change......and this is with new PCV from dealer. WIthout catch can, this would be sucking back into intake.
I remove TB back at thed end of November and took a peek. Plenum plate is clean! Alum plate install about a year prior to that.
Old Jan 22, 2013 | 12:43 AM
silverram22s's Avatar
silverram22s
Thanks everyone for the replys. I forgot to mention that it has new plugs, wires, and up stream o2 sensor. The dealer is the one that did the sinc on the dizzy and they put it at zero. I have not checked intake gasket yet. They led me to believe the chain was off a tooth but it was not. It just had a lot of slop. Any help is greatly appreciated so keep the replys comin lol
Old Jan 22, 2013 | 12:44 AM
silverram22s
Also cat is hollowed. Sorry forgot that also
Old Jan 22, 2013 | 12:49 AM
merc225hp's Avatar
merc225hp
Have you by chance done a compression test on this motor? Might be a good time to do one. There is a TSB on spark plug lead routing have you checked that as well?
Old Jan 22, 2013 | 01:14 AM
97tn4x4's Avatar
97tn4x4
Someone please explain to me how checking the timing with a light is going to do anything when the PCM controls timing. My plenum comment was based on spark knock which Even lurking will tell you that a plenum plenum will cause. Now idling rough can be a list of things but the op has already went through most of those, HOWEVER a vacuum leak can cause that. It could be a couple spots causing this, I had on on the front of my tb. On the other hand a leaking plenum is what..........? A vacuum leak. I used a really small light and an extendable mirror in the intake and I could see where the gasket was blown out. Now when I got it off it was worse than what it appeared but never the less when somebody asks for help checking the common problems first can make life alot easier.
Old Jan 22, 2013 | 09:41 PM
silverram22s
Im going to check the plenum next and no i have not done a compression check yet. Its weird cause if your driving normal it drives awesome. Will be working on it again tom night. Thanks again everyone
Old Feb 5, 2013 | 01:12 PM
silverram22s
Well i changed the intake gaskets and plenum. Also tps sensor and got the injectors rebuilt while they were out. Same issue still. Getting very irritated with this thing. Any help would be amazing
Old Feb 5, 2013 | 01:32 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
cap and rotor?
Old Feb 5, 2013 | 08:53 PM
What's your fuel pressure look like?
Old Feb 5, 2013 | 10:33 PM
silverram22s
Haven't checked the fuel pressure. Didn't really think of it i guess and cap and rotor look good, guess it wouldn't hurt to change them. What should the pressure be and would it cause my symptoms?
