Intermediate Shaft Bearing
Old 01-22-2013 | 10:52 PM
keepitrunning's Avatar
keepitrunning
Personally, I would stick with your original plan. Less work and money in the long run and at least you will know what you have. You may be opening a can of worms that you aren't prepared for. It has been explained that the brg/bushing is a reasonably easy fit and the seal can be done with 3 feet of redi-rod. Just my opinion.
Old 01-23-2013 | 12:03 AM
dhvaughan's Avatar
dhvaughan
i think a front axle housing swap would be a lot harder than replacing a bearing and seal. it'll require the removal of a lot of big parts.
if you take it all apart and replace the seals, both bushings. check/clean up the burrs on axle splines and collar. install a posi-lock, and replace axle u-joints, then you're done for a long long time.
http://www.pavementsucks.com/tech-article-3.html
http://www.pavementsucks.com/tech-article-5.html
Old 01-23-2013 | 08:59 AM
That sounds like the best plan to me.
Quick Reply: Intermediate Shaft Bearing
