compression test results (not good)
Old Jan 23, 2013 | 06:54 PM
stewie01's Avatar
stewie01
Originally Posted by 97tn4x4
You're suppose to hold the throttle wide open while doing the test. That can affect your readings.
How so? I ask because I did a compression test a while back (for ***** and giggles) and didn't know that I was supposed to hold it WOT...
I think I saw 150 on all but 1, cylinder 1, was a tad lower...
greanbeans's Avatar
greanbeans
Yes sir it is, but I have found it at other stores as well just have to hunt for it on the shelves. Great product.
Cool ill ha ve to get me some
Old Jan 23, 2013 | 06:55 PM
greanbeans's Avatar
greanbeans
Exactly
Old Jan 23, 2013 | 07:03 PM
crazzywolfie's Avatar
crazzywolfie
Wot will increase the compression numbers by giving the engine all the necessary amount of air to reach is full compression
Old Jan 23, 2013 | 07:09 PM
stewie01's Avatar
stewie01
Ah. Makes sense. I should go buy a compression tester and see what my numbers really are
Old Jan 23, 2013 | 07:15 PM
crazzywolfie
i wouldn't mind getting one of those fancier compression testers just for the extensions. then i could hook my air chuck to the adapter and do a leak down test.
Old Jan 23, 2013 | 07:41 PM
dhvaughan's Avatar
dhvaughan
How so? I ask because I did a compression test a while back ..... and didn't know that I was supposed to hold it WOT....
wide open throttle allows in maximum unrestricted air to compress. it might or might not give you slightly higher numbers. with throttle plate closed and iac closed the engine could theoretically starve for air.
to OP. those numbers aren't too bad. drive on another 100K miles.
Old Jan 23, 2013 | 09:49 PM
greanbeans's Avatar
greanbeans
Might be tradin for a ford 3/4 ton
Old Jan 23, 2013 | 09:52 PM
Now why on earth would you want to do that??
Old Jan 23, 2013 | 10:54 PM
greanbeans's Avatar
greanbeans
Truck is getting tired on me and I like fords lol but ill put dodge wheels on it atleast
