Power Door Lock Motor Replacement
Old Jan 23, 2013 | 04:40 PM
TheycallmeLaramie's Avatar
TheycallmeLaramie
Default Power Door Lock Motor Replacement
So I'm about to change both of my door lock motors/latches in my ram. Long time ago they stopped working intermittently and have gone completely out since then. I have been fine with it for a long time until recently my key cylinder in the truck broke and I had to replace it. Now I have to disarm my alarm (power locks wont open), use one key to open the door, and the other to start it. I've had enough too many steps . When I try to open either door with the power lock it just buzzes. Anyway got the whole setup and I'm about to do it today. I have the page printed in the service manual and it goes like this:
1) Take off door panel and plastic cover
2) Un-clip 4 rod linkages
3) take out three hex screws
4) pull motor out and un-clip wire harness
5) replace with new motor.
Simple enough right? Sure, my one question that I have for anyone that has already done this. How do you know which rods go to which colors? just mark them when your taking them apart? The manual says nothing about this. Or is it that just the four rods only reach the four clips and wont go any other way? Just figured I'd ask for advice. If all goes well I'll write us up a DIY on it. There is not one video on youtube for our model ram, and nothing in the DIY section, and I know this is a very common problem. Here's a pic of what I'm about to install
Laramie
Attached Thumbnails Power Door Lock Motor Replacement-kgrhqzrgfcd5bo45pbquqe8mzmq60_12_zps3ecf6c8c.jpg
Old Jan 23, 2013 | 04:46 PM
oxymoron29's Avatar
oxymoron29
Once in, it's blatantly obvious how they connect.
Too bad you bought new door actuators. If you peel those apart, you'll find a toy car DC motor powers them. Replace the brushes in these motors for $5 and they work like brand new.
Old Jan 23, 2013 | 05:02 PM
TheycallmeLaramie
So make a DIY for all of us and save us lots of money, please. I didnt spend a bunch 50 bucks a pop. 10$ vs 100$ is a good saving though. I saw a video on youtube of a guy taking apart a durango one to fix it and it didnt look fun. Sure if you know what your doing I guess. Or someone makes a DIY Service manual doesnt cover replacing the 5$ brush dc motor. I guess I could play with the old ones and try to replace it and make a DIY if i get them to work.
Old Jan 23, 2013 | 05:58 PM
oxymoron29's Avatar
oxymoron29
Yeah, of course the manual doesn't cover that. How would they make any money?
I always peel into stuff too quickly to think about DIY's. Looking at it in hindsight I wish I did as I've not seen anyone do it for Dodge stuff. It's a bit tedious, but taking pictures as you disassemble can help. A word to anyone that's going to try it: stick a C-clamp on the rear cover (not shown in the pics above) and keep it on as there are 2 springs in there that like to fly out when you take out the 2 philips bolts and they are a PITA to re-seat. After that you take the linkages underneath the gold plates off (take pictures) then use a utility knife to separate the two halves of the black plastic cover where the motor lies (piece where the power connector is). After that, you'll find a motor assembly with a gearbox inside. 2 Bolts hold the DC motor in. To slip the pinion gear out the chassis of the gearbox you need to very lightly file the tips of the pinion gear, as the hole is slightly smaller than the OD of the gear. Once done you slip the motor out, replace the brushes, and put it back together. I used a Mabuchi motor that was at a local supply store.
Old Jan 23, 2013 | 06:45 PM
Spillage's Avatar
Spillage
I'll be watching this with interest.
My passenger side lock has stopped working... it makes noise like stripped gears when actuated.
Old Jan 23, 2013 | 08:56 PM
Laramie
Where did you get those from?
Old Jan 24, 2013 | 11:11 AM
TheycallmeLaramie
Got those two off of ebay from a reputable seller. He told me they worked coming out and that he would return them if they did not function. Just got this done last night and it was reallllllllly easy. It was raining so I didnt take any pictures but I will describe it for anyone wanting to attempt it.
Old Jan 24, 2013 | 11:16 AM
TheycallmeLaramie
1) MAKE SURE THE WINDOW IS UP! If you hate electricity take the negative cable off your battery. I didn't but the service manual suggests that you do I think troubleshooting is easier without disconnecting reconnecting etc. Take out all the screws holding the door panel in place in mine there is two in the door handle cup and one where the rearview mirror would be.
2) Wiggle the switch plate with the unlock/lock and mirror up/down and pull it up. Then turn it sideways and gently guide it through the slot (believe me it will fit)
3) Gently pry on the bottom of the door panel at first slide your fingers across the bottom till you hit a plastic clip and do a peace sign around it and gently pull up. (Make sure you have extra door panel clips before attempting this some will always break)
4) Once you have them all out gently pull up and lift out, while you lift the inside door handle upwards.
5) When you get the door panel off take a sharpie and mark the bottom of the metal rod that has lock unlock plastic piece that you would manually lock and unlock with from the inside, then unscrew it off (this is so you know how far to screw it back in on install.
6) Peel down the plastic cover (or cut holes in the two openings nearest to the door.
7) Now that you can see the inside, I suggest looking at it will someone pulls the handle from outside and inside and manually locks from inside so you can see how the rods move and function.
8) There will be two rods in the back and two in the front. The furthest one in the back is from the manual door handle on the outside. The next furthest one is for the manual inside door lock. Next one closest is for the inside door handle, and the other one is for the inside door handle to open the lock when it’s locked.
9) If you look at the picture above you will see how the plastic clips work.
10) Next use a star bit to LOOSEN the three latch screws on the side. Do not take out completely. This is just to help free the plastic clips (you need a small hand and a little bit of patience)
11) Stick your hand through the bottom hole and go up and around, push the metal rod out of the plastic clip (looking to make sure your pushing the right direction) then pull the rod out. The one that goes to the manual lock you do not need to un-clip as you can pull it straight through without disconnecting.
12) Once you have all the rods disconnected with one hand holding the motor unscrew the other bolts you already loosened and the motor will come free.
13) There is a little plastic clip that holds the wiring to the door, push that in, guide the motor/latch around the window guide. Pull out of bottom hole and un-clip wiring harness.
14) Take the only rod you left on the old motor off and attach it to the new motor in the same position (manual door lock). Plug harness into new motor, and then use the power lock switch to lock and unlock and make sure mechanism moves up and down (save yourself time if you bought a dead one)
15) Guide the mechanism back in and around the window track making sure to put the manual lock bar into its proper slot on the top and tighten the three star bolts firmly.
16) Push the clip that holds the wiring to the door in and make sure it holds firmly.
17) Attach the other three rods (they only can reach one slot properly, there is no messing this up only breaking the clips so don't gorilla them). Make sure the plastic clip is positioned so when you put the rod into the hole it will clip onto the rod (there is only one way)
18) You should make sure that all the rods do not touch each other. One of my rods got bent taking it out of the clip and was rubbing another when I tried and wouldn't unlock. I bent the rod just slightly out of the way and bam worked perfect.
19) Test the door lock mechanism to make sure outside and inside door handles work as well as lock and unlock, and make sure the door handle inside unlocks the door when you pull it. Shut the door and open it to make sure the latch is working (Do this carefully if the latch is in the wrong position you won’t be able to shut the door and will end up breaking it if you slam the door). If the door won’t shut use a screwdriver to gently move the latch into the correct position (look at your old latch). Now if everything is all good you are ready to install back.
20) Screw the manual lock back down to the sharpie mark, tape up the plastic back into position
21) Check all your door panels clips and replace damaged ones
22) Guide the power switches through the panel and then the door panel over the door lock and over the door handle (lift up the door handle)
23) Push the panel back in working top to bottom making sure the clips go into the holes
24) Put all three screws back that hole the door candle cup and side-view mirror
25) Test all mechanisms one last time, and VIOLA! New power locks for 30-50$ a side compliments of ebay or 150$ each side if you decide to go get a new mopar latch/motor.
Old Jan 24, 2013 | 11:26 AM
Moved the other thread to the DIY section.
Wonder if there is a source for those new anywhere...... aside from the dealer.
Old Jan 24, 2013 | 11:31 AM
TheycallmeLaramie
HeyYou, believe me I SEARCHED. I couldn't find a source ANYWHERE. Ebay was the cheapest (basically buying from scrap yards) lowest I saw was 35$. I paid extra 55$ to get one that was from a 2001 (figured there was less locks and unlocks on it ) Mopar sells them for 150$ Cant buy them from pepboys/autozone/oreily etc. No one wants to make them because there are so many old 94-01 dodges if you want cheap you go to a scrap yard or ebay. If you want brand new Mopar sells them. Plus people like oxy who just refurbish them
