intake manifold torque sequence
Its actually a 7/8" nut and i was able to get at it with a wrench but i had to cut the wrench down into a stubby. I originally planned on deleting it but forgot the to bring the stuff with me so instead after removing the egr tube from the manifold and exhaust i cut the tube in the middle, flattend it out with a sledge and then folded the end over a couple of times. I would have just put it back on but the tube was bent in such a way that i could not get it to meet up on the exhaust manifold correctly, so this made it a whole hell of a lot easier. Later on down the road i will just plug the egr valve hole on the manifold, which can be done with just quick steel stick.
I just used a short crescent wrench for that nut for the egr. 6 inch crescent worked great. got it from the top of the engine. took some time but better than snaking my arm up there. Once I got it off, I unbolted it from the header and slid it out of the intake so I was able to just lift the intake up and out. Pretty much reverse process for putting it back on.
