Is it possible to upgrade from manual tow mirrors to power tow mirrors?
Old Jan 27, 2013 | 12:49 PM
stonedog1020's Avatar
stonedog1020
Cool Is it possible to upgrade from manual tow mirrors to power tow mirrors?
Hey everyone. First time poster here. I have a 01 3500 that the manual driver side mirror is shot. Truck has everything else power except mirrors. I have had door panel off both sides and looks like the wiring harness is in place for them. But I would have to get control **** and if I wanted heat to work then replace heater/ac control panel which has heated mirror button on it. Has anyone else tried this? Thanks for any help. If its gonna be too big of deal then I will just get manual but I hate manual mirrors.
Old Jan 27, 2013 | 01:12 PM
stewie01's Avatar
stewie01
I would think all you'd need to do is get one of those covers with the control **** off another Ram, check the JY's, and install the power tow mirrors.
Not sure about the heated mirror function, if your truck does have factory wiring for it I wouldn't see why it why it would be a problem.
Might check to see if the connectors have power going to them though.
Old Jan 27, 2013 | 02:21 PM
stonedog1020
Ok I may go ahead and look for those before I order mirrors. I will also check for power to those harnesses also. Thanks for the tip.
Old Jan 27, 2013 | 03:04 PM
Jimythefan's Avatar
Jimythefan
Yes, I have done this. I found the control **** on ebay for very short money. Replaced the HVAC control with the correct unit with mirror heat button, again for short money on ebay. Sold my factory manual mirrors locally on craigslist and bought the heated power ones. Everything was plug and play.
Old Jan 31, 2013 | 07:36 PM
stonedog1020
Thanks again for the help everyone. I am working on this project now.
Old Jan 31, 2013 | 08:09 PM
oxymoron29's Avatar
oxymoron29
You'll need an entire driver's side door panel.
Old Jan 31, 2013 | 08:32 PM
gdstock's Avatar
gdstock
Or figure out some other way to mount mirror control switch...
Old Feb 1, 2013 | 06:05 PM
stonedog1020
Thanks but I think I already have the right door panel. It has a spot where it goes and a plastic cap in it right now.
