transfer case
Old Jan 27, 2013 | 08:48 PM
Lone136's Avatar
Lone136
Question transfer case
Here is one for you. I have a 99 Ram and I do know there should be TF4 in the transfer case, but after I had a center pin break in the rear lift spring this past week I found gear oil coming from the tail shaft of the transfer case. It also seems the seals on the transfer case are leaking as well. What should I put back into the transfer case
Old Jan 27, 2013 | 09:47 PM
I would flush it out REALLY well, then refill with ATF +4....
Old Jan 28, 2013 | 12:03 AM
Wombat Ranger's Avatar
Wombat Ranger
Not really a big deal actually. ATF+4 is only required so that when tranny/tcase seals fail and they swap fluids there isn't supposed to be immediate catastrophic failure. No clutches or friction surfaces in the Tcase to be picky. If it's thick and slick, the Tcase don't mind.
