urgent help 200046re problems
Old Jan 28, 2013 | 01:59 AM
ramrookie92's Avatar
ramrookie92
Wink urgent help 200046re problems
okay i had a thread already and people stopped replying to it so heres the problem. tranny started hangin 1stand 2nd gear and slipping in drive. i have a dealer adjust bands and tv cable installed a new gov solonoid and a new presure transducer and a filter and fluid change. seemed fine but seemed like it wasnt getting up as fast in first when it was in drive. then shortly after i get a gov pressure malfunction code twice andnitnwent away both times. sometimes in drive it will barley have enough grip to climb a curb but other times its fine. and it seems like it surges more often and likes to shift clunky some times and i dont have enough for a rebuild right now and need help quick. thank u
Old Jan 28, 2013 | 09:17 AM
Check TPS, and trans fluid level. (in neutral) If those are ok..... start looking for a used trans to get you by till you can afford a rebuild.
Old Jan 28, 2013 | 10:25 AM
gdstock's Avatar
gdstock
Can you elaborate on the meaning of this part?
Old Jan 28, 2013 | 10:29 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Better get some money because it sounds like a rebuild is in order.
Old Jan 28, 2013 | 10:32 AM
gdstock's Avatar
gdstock
+1, and I suspect there is more than one problem going on.....but that's just me.....
Old Jan 28, 2013 | 10:33 AM
Ever the optimist?
Old Jan 28, 2013 | 10:47 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Ever the optimist?
Nope. Like me, he's a realist.
Old Jan 28, 2013 | 10:55 AM
wolfpack360's Avatar
wolfpack360
Hey I had a similar problem and it was a bad downstream 02 sensor not sure what code you're getting but mine was a high or low voltage for the Governor Pressure solenoid. It would take off in like third and have hardly any power you could always try unplugging it and see if that helps. Also I think I wrote this on your other thread but can you manually shift into 1st could help us figure out if its a valve body problem or a computer problem.
Old Jan 28, 2013 | 11:00 AM
gdstock's Avatar
gdstock
Ever the optimist?
In reality, I am an optimist! If I was a pessimist, I would aske why the heck are we driving over curbs.....
Old Jan 28, 2013 | 12:59 PM
ramrookie92
theres a parking lot that exits to a road and it has a 6to7inch lip between the dirt and thr pavment and when i went to leave i had to drive over it and it just slipped and didnt go. put it in 1st no problem. thatsbwhat i ment by curb and im pretty sure it needs rebuilt.
