Lost Overdrive
Old Jan 31, 2013 | 07:53 AM
petea216's Avatar
petea216
Nice, sometimes the $500 trucks are the best ones! I paid $450 for mine.
Old Jan 31, 2013 | 02:30 PM
TheBigRedTruck's Avatar
TheBigRedTruck
in the process of doing my plenum. drained over half the antifreeze. tempuratures dropped to below freezing overnight. i put the truck in neutral to push it elsewhere on the driveway. as the truck shook, antifreeze poured out from behind the engine. i can't see where it's coming from. what could cause this? my antifreeze was always at above 50/50 mix, like 55/45 to be safe.
Old Jan 31, 2013 | 02:38 PM
Is the intake off? There are coolant ports on the back of the heads, that are normally covered by the intake.... it could easily splash out of there when pushing the truck.
Old Jan 31, 2013 | 05:45 PM
TheBigRedTruck
on the back or on top? i noticed coolant up to the brim on the ports. that is possibly it.
Old Jan 31, 2013 | 10:40 PM
Toward the back, on the intake manifold mating surface. Normally are blocked by the intake gasket.
Old Jan 31, 2013 | 11:24 PM
TheBigRedTruck
yea i can see it, hopefully it was just that
Old Feb 3, 2013 | 02:44 PM
bigaaron's Avatar
bigaaron
back to your trans problem with no O/D check your 3-4 accumulator spring. They have a tendancy to break, are easy to get to with the trans still in the truck, and there is an upgrade at cascade transmission. (getting ready to do mine)
Old Feb 8, 2013 | 12:34 PM
TheBigRedTruck
looking to remove heat from truck. heater core doesn't work and don't want to replace it. is it safe to route the heater hose from the water pump directly back into the intake manifold instead of going in the heater core?
Old Feb 8, 2013 | 12:38 PM
Just bypass the heater core, hook the hoses together.
Old Feb 8, 2013 | 05:03 PM
TheBigRedTruck
thats what i thought. thanks.
