96 1500 front dana 44 ?
Old Feb 2, 2013 | 12:56 PM
getdown78's Avatar
getdown78
Default 96 1500 front dana 44 ?
I am looking at changing the gears in my truck from 3.54 to 4.88 for the 36" tires but i found a new set that are for a jeep non rubicon but will they work ?
Old Feb 2, 2013 | 01:38 PM
newman1367's Avatar
newman1367
no they won't
Old Feb 2, 2013 | 03:00 PM
Wombat Ranger's Avatar
Wombat Ranger
If they are standard Dana 44 (non rubicon like OP said) why wouldn't they work? I don't pay much attention to jeep crap, forgive my ignorance. I know the JK-44's are different. OP are they still dana 44 gears?
Old Feb 2, 2013 | 03:41 PM
newman1367's Avatar
newman1367
The non rubicon jeep TJ and JK only came with dana 30's as far as I know
Old Feb 2, 2013 | 04:06 PM
Wombat Ranger
That's why I asked the OP if they were still 44 gears. Some early Cherokees and Comanches had a 44 rear end with the tow package. Also some cj-7's got 44's out back I think. Many of the FSJ's (Wagoneers, J-trucks, full size Cherokees) had 44's also. That's why I was asking for more info.
Old Feb 2, 2013 | 04:40 PM
newman1367's Avatar
newman1367
I may have misunderstood what jeep they were out of. If its a dana 44 standard rotation front set from any of these, they will work.
cj-6 71-75
comanche 86-92
grand wagoneer 84-91,93
j-10 67-88
wagoneer 74-92
Old Feb 2, 2013 | 05:42 PM
Wombat Ranger
Is there a difference in standard rotation front and rear gears?
Old Feb 2, 2013 | 07:00 PM
newman1367's Avatar
newman1367
If I'm thinking correctly, you can physically put a rear set in a front axle. You'll just be driving the ring gear on the coast side, which reduces the strength of the ring gear by about 20%.
Old Feb 2, 2013 | 08:55 PM
Wombat Ranger
Low pinion diffs all use stardard rotation gears. Thats why low pinion frints are weaker than high pinions, which use reverse rotation gears. Standard rotation gears are the same front or rear.
Old Feb 3, 2013 | 01:42 AM
94Beater's Avatar
94Beater
You'll also need a thick gear for your axle. Front 44 carrier can only go 3.92, before you have to use thick gear. Otherwise you will need to change a whole new carrier.
Don't even bother using some stuff that might work. Get the right parts from the start and you'll have no problem. Go to Randy's Ring and Pinion site and do little research on your axle.
