Cold start
Old Feb 4, 2013 | 09:51 AM
Bad connections, wrong readings. (need something that can read the data stream for that though.)
Old Feb 4, 2013 | 01:33 PM
PmuLLin's Avatar
PmuLLin
I had auto zone run a code reader an nothing came up, or would I have to connect direct to the PCM?
Old Feb 4, 2013 | 03:06 PM
All that means is the PCM doesn't think there is a problem. That does NOT necessarily imply that there isn't one.
Need to be able to read data. And see what the sensors are telling the PCM at cold start. Most code readers will also read data...... just having one at the right time is the tough part.
Old Feb 4, 2013 | 06:23 PM
PmuLLin's Avatar
PmuLLin
Can I replace the PCM, stupid question? Ha I'm learning as the problems develop with this truck.
Old Feb 4, 2013 | 06:56 PM
97ramrod1500's Avatar
97ramrod1500
The check engine light only comes on if there is a problem effecting emissions. Most parts stores only use cheap generic code readers and if there's no cel, their reader won't show anything.
Old Feb 4, 2013 | 07:50 PM
PCM is probably fine. You got something else going on there.
Old Feb 5, 2013 | 12:28 AM
gdstock's Avatar
gdstock
Originally Posted by PmuLLin
Would you suggest I try what bigarron said? This morning it was 15 degrees and it almost started right up, maybe turned over one or two extra times then normal. Or try looking at the temp sensor for the PCM, what am I looking for though?
It wouldn't hurt, and has no cost.
Old Feb 5, 2013 | 06:29 PM
bigaaron's Avatar
bigaaron
you might just have some garbage gas. I started using mid-grade since this happened. This morning in Mid-michigan it was -3 degrees and my truck strated right up.
