random start problem
Old Feb 10, 2013 | 04:54 PM
97ramrod1500's Avatar
97ramrod1500
When its cranking but not starting; if you push on the gas does it start or just keep cranking?
Old Feb 11, 2013 | 03:48 PM
84powerram's Avatar
84powerram
no the gas dose nothing if I mash it
Posted from Dodgeforum.com App for Android
Old Feb 11, 2013 | 03:59 PM
84powerram's Avatar
84powerram
thanks I did the key trick and got p0340 code
Old Feb 11, 2013 | 04:03 PM
84powerram's Avatar
84powerram
what other problems will the p0340 code cause
Old Feb 11, 2013 | 04:04 PM
P0340 No Cam Signal At PCM
Cam position sensor is toast. (it's under the dist cap, generally referred to as "pickup coil".)
Old Feb 11, 2013 | 04:11 PM
84powerram's Avatar
84powerram
what other problems can the p0340 code cause
Old Feb 11, 2013 | 04:16 PM
No start, rough running, backfiring, and a host of other performance problems.
Old Feb 11, 2013 | 05:30 PM
84powerram's Avatar
84powerram
the truck deals week gets bad mpg and ideals rough could that's cause that
