2000 magnum 5.9 to np435
Old Feb 11, 2013 | 06:32 PM
Jacobanstett's Avatar
Jacobanstett
Default 2000 magnum 5.9 to np435
hey guys new to this forum but im putting a 2000 dodge 360 into my 89 jeep yj and was recommend by novak conversion that the np435 was a choice. was looking on the novak site and jeep forum but there wasnt to much info about mating it to a newer 360 and what clutch flywheel pressure plate etc id need. any help would be great thanks
Old Feb 11, 2013 | 06:47 PM
Hahns5.2's Avatar
Hahns5.2
You're going to have a problem using the correct 143t flywheel for the crank sensor with that tranny (meant for use with a 130t flywheel).
Old Mar 19, 2013 | 10:32 AM
won't work's Avatar
won't work
Hi Jacob, i joined this forum just to answer your question. The magnum motors can be mated to a np435 very easily i have done it twice. I used the factory flywheel for the engine to work with the crank position sensor and everything else from a 88-91 dodge truck. Notch the bellhousing for the crank position sensor and everything else will just bolt together.
Old Jul 26, 2018 | 03:03 PM
David_'s Avatar
David_
I know this is old, but I'll try anyway.
I have a 93 5.9 magnum i am trying to put on a np435 and the ring for the crank sensor will not fit with the flywheel also on. Any advice for that?
Old Jul 26, 2018 | 07:57 PM
Could you use the original 5.9 flywheel? Bear in mind, the 93 360 is EXTERNAL balance, which means the flywheel is an integral part of that balance.
