knocking from Dr side axle
Old Feb 11, 2013 | 11:38 PM
cutthroatxxx's Avatar
cutthroatxxx
Default knocking from Dr side axle
So the other day my front drivers side of axle started sounding like rusty bed springs bouncing up&down then tonite it started making a knockng sound.I don't know if you've ever had a engine throw a rod but that's what it sounds like just from the drivers side axle.I'm guessing its the ujoint if I grab it it moves just a hair.As the pass side moves none.Any ideas?
Old Feb 12, 2013 | 12:19 AM
Bull Bainter's Avatar
Bull Bainter
Originally Posted by cutthroatxxx
so the other day my front drivers side of axle started sounding like rusty bed springs bouncing up&down then tonite it started making a knockng sound.i don't know if you've ever had a engine throw a rod but that's what it sounds like just from the drivers side axle.i'm guessing its the ujoint if i grab it it moves just a hair.as the pass side moves none.any ideas?
i think you've nailed the problem. This last jan i was involved in rebuilding 4x4 front axles ( five of them) every one of them experienced "clunking", squeeking, and vibration while in four-wheel drive.
Old Feb 12, 2013 | 01:18 AM
cutthroatxxx
This does it while in 2wd I haven't drove in 4x4 to see if it does it,only drove a few inches to 4x to make sure it was engaging.I'm also wondering if it could possibly br the driveshaft.
Old Feb 12, 2013 | 07:09 AM
dhvaughan's Avatar
dhvaughan
front axle turns even in 2wd (drive shaft does not unless CAD is stuck in engaged position).
when twisting the u-joint, there should be zero movement. any movement at all indicates bad.
http://www.pavementsucks.com/tech-article-5.html
http://www.pavementsucks.com/tech-article-3.html
Old Feb 12, 2013 | 09:36 AM
Check the lower shock bushings as well.
