weird noise in bell housing
Old Feb 12, 2013 | 10:01 PM
gdstock's Avatar
gdstock
Originally Posted by tyler870
cause i had tranny rebuild 1500 miles back maybe they screwed up my tc or didnt use loctite an there lose...
STOP driving it around! Take it back to who did the rebuild and let them fix it before you screw something else up. Do NOT work on it. This allows them an out to not stand behind their work. If I rebuilt one for someone and they came in and told me they had issues and did some things on it, I would be hesitant to take responsibility for something they may have casued.
TAKE IT BACK TO THEM! See if they can find the issue. If it is a noise, it could be doing damage.
And it would have been helpful if you would have posted the tranny was rebuilt in your first post. The more information we have, the better. Also, put your truck info in signature.
Old Feb 12, 2013 | 10:03 PM
tyler870's Avatar
tyler870
Default o2
i ran codes on it tonight code said 02 sensor,trans sensor/torque convert solineid ,air condition relay circuit..would any these give me loss of power????
Old Feb 12, 2013 | 10:08 PM
gdstock's Avatar
gdstock
O2 Sensor could do this, and clogged cat could also.
BUT...
Old Feb 12, 2013 | 10:10 PM
tyler870's Avatar
tyler870
Default o god
well i purchased it from someone else dont know who they used or how get hold of em,the tranny shifts fine though,,the clunking has jus recently started but i dont know what to do i dont have money to pour into the thing if i check tc for lose bolts an nothing is wrong i may have more major problems your saying?i hate to get rid of it but i dont have money for new tranny sittin on bout 500 bucks dont have income to buy trranny an pay to put it in...
Old Feb 12, 2013 | 10:50 PM
gdstock's Avatar
gdstock
i ran codes on it tonight code said 02 sensor?
Check wiring connector to O2 sensor. Make sure it is plugged in and tight. If upstream, it may be dumoing fuel and running pig rich.
....trans sensor/torque convert solineid...
Check connectors on side of tranny. Remove, clean, and reconnect.
...air condition relay circuit..
No.
I would be suspicious of someone who did not rememebr who they recently had rebuild a transmission. Not like it is incidental. There is something they are not saying for some reason.....
Old Feb 12, 2013 | 10:57 PM
tyler870's Avatar
tyler870
ima get hold of em tomorow an see who did the job ill also try everything u guys said i thank you guys very much i was probly sold a lemon it ran fine for days than all sudden started this sucks for me i got rid of a good chevy to buy this an now im outta ride but thanx again ill post tomorow an see if i figured it out
Old Feb 12, 2013 | 11:00 PM
gdstock's Avatar
gdstock
It may not be that bad a problem. Hopefully you can find out who dd the work and he will stand behind it. Think positive.
Old Feb 12, 2013 | 11:07 PM
tyler870's Avatar
tyler870
hope so man can you tell me where the o2 sensors are cuz im not sure if i have cats seein he had 18'' glasspacks put on....
Old Feb 12, 2013 | 11:20 PM
tyler870's Avatar
tyler870
ok couldnt sleep thinking bout this crap so im working have discovered that my tranny mount on the cross member looks kinda caved in could this cause my clunking.....maybe its making my tranny sit a little off angle and binding it some how
Old Feb 12, 2013 | 11:28 PM
gdstock's Avatar
gdstock
O2 sensors are installed in the exhaust piping. Upstream is near the pass side exhaust, usually right at the front of the cat. Screws into port. There should be a connector hanging there somewhere if it is out. Second one is behind cat in exhaust pipe. If the front one is not there, it would be running rich as the PCM dumpe fuel becasue the missing signal indicates lean condition.
That could be a problem. Check crossmember and make sure it is bolted in correctly and trans mount is good and secure. Also check engine mounts. Engine and tranny should eb straight, Being cocked can cause u joint failure, tear uo tranny extension housing, etc.
