weird noise in bell housing
Old Feb 12, 2013 | 05:28 PM
tyler870's Avatar
tyler870
Default weird noise in bell housing
have 1994 dodge ram 1500 recently started making clunking noise in bell housing can not diagnose problem..maybe tc or flexplate need help plzzz
Old Feb 12, 2013 | 06:18 PM
Does it do it in neutral? Or only in gear?
Old Feb 12, 2013 | 08:19 PM
tyler870's Avatar
tyler870
just in park im thinkin tc or flex plate but im not sure...
Old Feb 12, 2013 | 08:20 PM
tyler870's Avatar
tyler870
an also experinceing loss of power would either of these cause this
Old Feb 12, 2013 | 09:06 PM
gdstock's Avatar
gdstock
What do you mean by loss of power? When is it doing it, and waht conditions.? Info on truck would help a little also.
Old Feb 12, 2013 | 09:12 PM
tyler870's Avatar
tyler870
Default trouble
i was doin bout 50mph on highway been running bout 12 miles now an all sudden jus loses power it doesnt die just kicks out i pull over give it a second an take off again running jus fine give ran it another 12 miles an it does it again oil pressure is good not over heating fluids are fine...when i return home notice a slight cluking sound in bell housing..
Old Feb 12, 2013 | 09:45 PM
Hhhmmm.... if it only does it in park.... probably not the flex plate. If the plate were cracked/broken, it would get REALLY loud when you put it in gear.
Old Feb 12, 2013 | 09:53 PM
tyler870's Avatar
tyler870
Default helllll
well if not flex plate what bout if the tc bolts are lose or have fell out or flywheel broke or cracked would either those make make the noise and make me lose power not sure if i hav cats have 18'' glasspacks an dont think cats are on....
Old Feb 12, 2013 | 09:54 PM
tyler870's Avatar
tyler870
cause i had tranny rebuild 1500 miles back maybe they screwed up my tc or didnt use loctite an there lose...
Old Feb 12, 2013 | 09:58 PM
Judd360's Avatar
Judd360
yeah check your torque converter bolts make sure they are not loose. Probably wouldnt cause power loss but its worth a look
