Quick exhaust question
Old Feb 15, 2013 | 07:50 AM
  #21
Cool. As long as there is no inspections I guess your good. Here in NC they do a visual only on cars made before 1996. If it came with emissions devices from the factory, they check it. They don't necessarily have to work but they do have to be there. What i've see guys do around here is gut the cat and have a piece of straight pipe welded inside it so it will pass inspection.
Old Feb 15, 2013 | 08:00 AM
  #22
ccd1977's Avatar
ccd1977
Ok. So will i take a hit in the mpg area?
Old Feb 15, 2013 | 09:07 AM
  #23
Probably not.
Well..... maybe. Depends on your driving style. It's gonna be louder, and that may tempt you to step harder on the gas, as it sounds kinda cool...... so, gas mileage may go down. Aside from that, if the cat is getting clogged, might even pick up a bit.
Old Feb 15, 2013 | 09:59 AM
  #24
ccd1977's Avatar
ccd1977
Ok. I am going to replace the o2 sensor too while i am at it. I am pretty tempermental with my foot so that should not be that big of an issue. Do you recommend the Bosch sensors? Also, i am having a hard time finding the exact part number i need. Any advice?
Old Feb 15, 2013 | 10:25 AM
  #25
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
NO!! Bosch 02 senors. These truck HATE them.
Use the NTK sensors.
Old Mar 19, 2013 | 03:52 PM
  #26
ccd1977's Avatar
ccd1977
ok. So I had the exhaust done. Cat removed and he put a VX muffler on there. I have no idea what that kind is. He routed the exhaust higher along the side and told me that was to keep it out of the way in case I 4x4. Replaced O2 and now my gas has gone down some. I think I may have lost some low end power too.
Ideas?
Old Mar 19, 2013 | 04:51 PM
  #27
Reset the PCM, drive if for a few days. Let it re-learn the new conditions. See what happens.
Old Mar 19, 2013 | 05:58 PM
  #28
ccd1977's Avatar
ccd1977
ok. isnt that when i disconnect the positive terminal and i lose my radio staions?
i did that last week after it was done. i also changed out my tps sensor two days ago and removed the positive cable for that also.
Old Mar 19, 2013 | 06:01 PM
  #29
redneck_ram's Avatar
redneck_ram
Long tube is better for low end torque.
Shorties are easier to install and have better top end and mid range.
uh...... long tubes are SUPER easy to install! i did it by my self in 10 minutes, without any help, and holding the gaskets in place too. it was a fun, and kinda odd ordeal, but easy as hell!
Old Mar 19, 2013 | 06:49 PM
  #30
dhvaughan's Avatar
dhvaughan
Originally Posted by ccd1977
If i remove the cat, will my cel go off?
my 01 did not register any codes, complaints, or CEL lights.
