So I had my brother order the timing set, he gets a discount I told him a double roller but that's not what I got, it's a cloyes 3072 is the model. The chain is designed like a high energy not a double roller. Should I go through the trouble of returning it and getting a DR or will this one be sufficient performance?
Even the comp cams guys have cast iron cam gears, and steel crank gears...... I don't think its all that unusual. I got the SA Gear (I think that's right) from advance. Nice set. works great. Been in there for over a year now.....
Alright I will return it today and get the autozone kit. Two of the waterpump bolts were rusted pretty bad and I noticed the water passages in the timing cover look like they are cracked. Is this common? Found local used ones available for $32. All the block threads are good, I was sweating bullets at first lol
